Ir para o conteúdo principal
Casio CTK-501 LCD Screen Replacement
O que você precisa
  1. Casio CTK-501 LCD Screen Replacement, Bottom Panel: passo 1, imagem 1 %32 Casio CTK-501 LCD Screen Replacement, Bottom Panel: passo 1, imagem 2 %32
    • Flip the keyboard over so that the bottom is facing up.
    • Remove the twenty-seven 12 mm screws from the dark-grey panel using a Phillips #2 screwdriver.
    Pergunte ao FixBot
    Comentar
  2. Casio CTK-501 LCD Screen Replacement: passo 2, imagem 1 %32
    • Remove the bottom panel by lifting and pulling it towards yourself.
    Pergunte ao FixBot
    Comentar
  3. Casio CTK-501 LCD Screen Replacement: passo 3, imagem 1 %32 Casio CTK-501 LCD Screen Replacement: passo 3, imagem 2 %32
    • Flip open the top half of the keyboard.
    • Set the keyboard onto the bottom half with the internal parts facing up.
    • Be careful not to let the bottom drop.
    Pergunte ao FixBot
    Comentar
  4. Casio CTK-501 LCD Screen Replacement, LCD Screen: passo 4, imagem 1 %32
    • Completely unscrew and remove all six of the screws on the central circuit board.
    Pergunte ao FixBot
    Comentar
  5. Casio CTK-501 LCD Screen Replacement: passo 5, imagem 1 %32
    • Lift the circuit board out of your way.
    Pergunte ao FixBot
    Comentar
  6. Casio CTK-501 LCD Screen Replacement: passo 6, imagem 1 %32
    • Remove tape from the LCD screen and remove the screen completely.
    Pergunte ao FixBot
    Comentar
  7. Casio CTK-501 LCD Screen Replacement: passo 7, imagem 1 %32 Casio CTK-501 LCD Screen Replacement: passo 7, imagem 2 %32
    • Replace the LCD screen and tape it down to the top cover.
    Pergunte ao FixBot
    Comentar
  8. Casio CTK-501 LCD Screen Replacement: passo 8, imagem 1 %32
    • Place the circuit board back on top of the LCD screen.
    • Screw all of the screws completely in their original positions.
    Pergunte ao FixBot
    Comentar
Conclusão
Jimmy Winne
Membro desde: 10/04/12
578 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 9-16, Amido Fall 2012 Membro de Cal Poly, Team 9-16, Amido Fall 2012
CPSU-AMIDO-F12S9G16
4 Membros
Autoria de 6 guias
3Comentários do guia
Where did you get the replacement LCD screen? I'm looking for one for my CTK-573 keyboard mbuseck1@yahoo.com
mbuseck1 - Responder Compartilhar
Hi. Would this screen work for CTK 481?
José Saldaña - Responder Compartilhar
hi. I have the ctk 4300. i would like to know where i can get one.Binitintimo@gmail.com
timo binitin - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 34
Ao todo: 5,882
