Ir para o conteúdo principal
Casio CTK-501 Battery Connection Replacement
O que você precisa
  1. Casio CTK-501 Battery Connection Replacement, Bottom Panel: passo 1, imagem 1 %32 Casio CTK-501 Battery Connection Replacement, Bottom Panel: passo 1, imagem 2 %32
    • Flip the keyboard over so that the bottom is facing up.
    • Remove the twenty-seven 12 mm screws from the dark-grey panel using a Phillips #2 screwdriver.
  2. Casio CTK-501 Battery Connection Replacement: passo 2, imagem 1 %32
    • Remove the bottom panel by lifting and pulling it towards yourself.
  3. Casio CTK-501 Battery Connection Replacement: passo 3, imagem 1 %32 Casio CTK-501 Battery Connection Replacement: passo 3, imagem 2 %32
    • Flip open the top half of the keyboard.
    • Set the keyboard onto the bottom half with the internal parts facing up.
    • Be careful not to let the bottom drop.
  4. Casio CTK-501 Battery Connection Replacement, Battery Connection: passo 4, imagem 1 %32
    • Plug in the soldering iron.
    • Set the soldering iron somewhere safe, where it can't catch anything on fire.
    • Unscrew the top green circuit board with black and red wires running through it.
  5. Casio CTK-501 Battery Connection Replacement: passo 5, imagem 1 %32
    • Set the circuit board somewhere flat so it is safe to solder.
  6. Casio CTK-501 Battery Connection Replacement: passo 6, imagem 1 %32
    • Heat up the solder covering the end of the wires connected to the circuit board.
    • Once the solder melts, remove the wires from the circuit board.
  7. Casio CTK-501 Battery Connection Replacement: passo 7, imagem 1 %32
    • Melt new solder with your soldering iron.
    • Then apply it over the tip of the wire resting on the circuit board.
  8. Casio CTK-501 Battery Connection Replacement: passo 8, imagem 1 %32
    • Once the wires are firmly attached, screw the circuit board back into the keyboard.
Conclusão
3 outras pessoas executaram este guia.
Jimmy Winne
Membro desde: 10/04/12
578 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 9-16, Amido Fall 2012 Membro de Cal Poly, Team 9-16, Amido Fall 2012
CPSU-AMIDO-F12S9G16
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 35
Duração total: 4,813
