Ir para o conteúdo principal
Casing and Trigger
O que você precisa
    1. Casing and Trigger, Fellowes T7CM Casing and Trigger Replacement: passo 1, imagem 1 %32
      • Check to make sure the shredder is not plugged in to any electrical outlet.
      • Remove the shredder from the catch basket and place the silver side down on a flat surface.
      • Place the catch basket aside as you will not be needing it for the rest of the disassembly.
      Pergunte ao FixBot
      Comentar
    2. Casing and Trigger: passo 2, imagem 1 %32
      • Flip the shredder silver side down and place on a flat even surface.
      • Remove the manufacturer's label in order to gain access to the hidden screw hole.
      • Locate all five of the case screws and remove them with a Phillips-Head screwdriver. The screws are located within the five marked circles in the photo. The size of the screws are 18 mm in length and head diameter of 5 mm.
      Pergunte ao FixBot
      Comentar
    3. Casing and Trigger: passo 3, imagem 1 %32
      • Once all of the screws are removed, slowly pull apart the casing.
      • If the casing is not separating, gently wiggle the top part of the casing from the bottom part of the casing.
      • Use Caution during this procedure to prevent from damaging any of the internal parts.
      Pergunte ao FixBot
      Comentar
    4. Casing and Trigger: passo 4, imagem 1 %32
      • Open the casing as shown to prevent tangling or damaging the wires.
      • Take note to how the trigger assembly is attached before removal.
      • The trigger assembly is one part and should come off all together with little to no force applied.
      • Remove the trigger assembly.
      Pergunte ao FixBot
      Comentar
Conclusão
4 outras pessoas executaram este guia.
John Wisthoff
Membro desde: 10/12/16
487 Reputação
Autoria de 3 guias
Equipe
IUPUI, Team 2-2, Baechle Fall 2016 Membro de IUPUI, Team 2-2, Baechle Fall 2016
IUPUI-BAECHLE-F16S2G2
4 Membros
Autoria de 16 guias
2Comentários do guia
-Group 1 Recommendations-
Use Caution - Should use the 'Caution' bullet. (Click on the bullet to change bullets)
Take note - Should use the 'Note' bullet.
Second to last bullet on the last step - Should be a note because it is not stating a step, it is a note or reminder for the user.
Deanna Jack - Responder Compartilhar
Where can i buy replacement gears for this shredder?
indymoon - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 12
Últimos 30 dias: 49
Ao todo: 4,812
