Introdução
If your car or truck won't start, it may be time to change the battery. A typical motor vehicle battery lasts about 3-4 years, but this lifespan can vary greatly depending on the conditions and your driving habits.
This guide uses a Toyota Corolla to demonstrate the procedure, which is similar to most common motor vehicles.
If you just need to temporarily disconnect the battery rather than remove or replace it, follow this shorter guide.
Warning: Modern vehicles with a start-stop system often have a battery management system (BMS) that makes it necessary to pair the battery with special equipment after a replacement. A disconnected battery can cause infotainment, powered windows, and other vehicle electronics to lose their settings and require re-initialization. In some cases, error codes must also be resolved. Consult your owner's manual for details.
O que você precisa
Make sure the transmission is in Park (or first gear if you have a manual gearbox) and that the parking brake is engaged.
In addition to being dirty, the battery contains corrosive agents and may release flammable gases.
Gloves can also help protect you from an unpleasant shock if you accidentally mishandle the battery.
If you're not sure, simply continue reading.
Pull the hood release lever. It's usually located inside the car, near the steering wheel.
Remove the insulating cover from the positive battery terminal (if one is present).
37 outras pessoas executaram este guia.
4Comentários do guia
You should not just tell people to follow the directions in reverse order for reassembly. There are some steps most mechanics will want you to perform (e.g. applying a compound to the terminals to prevent corrosion) in addition to simply reattaching the cables.
As with most guides on iFixit, reassembly tips are included on the applicable step where appropriate.
good for car batery replacement
If a battery has water around it and has no power should I charge it.
