Ir para o conteúdo principal
Capresso Perfectea 260 Lid Replacement
O que você precisa
  1. Capresso Perfectea 260 Lid Replacement, Lid: passo 1, imagem 1 %32
    • Lift the lid of the Perfectea
    • Remove the two 12mm Phillips #2 screws located at the brim of the pot.
    Pergunte ao FixBot
    Comentar
  2. Capresso Perfectea 260 Lid Replacement: passo 2, imagem 1 %32 Capresso Perfectea 260 Lid Replacement: passo 2, imagem 2 %32 Capresso Perfectea 260 Lid Replacement: passo 2, imagem 3 %32
    • Adhesive tape is left holding the lid to the glass pot.
    • Use the spudger for this step.
    • With one hand, firmly grip the lid while designating your other hand to wedge the spudger between the lid and the glass pot.
    • Working from the outside to the inside, gently pry the adhesive tape from the glass pot, detaching the lid.
    Pergunte ao FixBot
    Comentar
Conclusão
Kenji Anzai
Membro desde: 04/14/15
594 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 6-17, Maness Spring 2015 Membro de Cal Poly, Team 6-17, Maness Spring 2015
CPSU-MANESS-S15S6G17
4 Membros
Autoria de 12 guias
2Comentários do guia
This guide applies to the Capresso H2O kettle too. Thanks for the guide.
Giovanni Ciriani - Responder Compartilhar
What kind of adhesive tape is it and where can I get some? That piece that you pried off had already fallen off of my kettle.
George Shaeffer - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 29
Ao todo: 1,026
