Introdução
If you need to repair any of the wires or computer chips, use this guide to remove these components for repair and replacement.
O que você precisa
Remove the two 7.5mm Phillips #2 screws from the metal frame.
Remove the frame from the assembly.
Find the cable that attaches the small computer chip to the heating element connections.
Use the spudger to cut open the rubber coating on the latch where it clamps onto the copper tab.
Insert the metal spudger into the rectangular hole on the latch and push toward the tab (away from the wire) to unbend the tab.
Push the latch off the tab with the spudger.
Uma outra pessoa concluiu este guia.
