Ir para o conteúdo principal
Capresso Infinity Timer/On Switch Replacement
O que você precisa
  1. Capresso Infinity Timer/On Switch Replacement, Metal Outside Casing: passo 1, imagem 1 %32 Capresso Infinity Timer/On Switch Replacement, Metal Outside Casing: passo 1, imagem 2 %32
    • Twist the top plastic container to the left counterclockwise.
    • Pull upwards to remove.
    Pergunte ao FixBot
    Comentar
  2. Capresso Infinity Timer/On Switch Replacement: passo 2, imagem 1 %32 Capresso Infinity Timer/On Switch Replacement: passo 2, imagem 2 %32 Capresso Infinity Timer/On Switch Replacement: passo 2, imagem 3 %32
    • Twist the top burr to the left counter clockwise.
    Pergunte ao FixBot
    Comentar
  3. Capresso Infinity Timer/On Switch Replacement: passo 3, imagem 1 %32 Capresso Infinity Timer/On Switch Replacement: passo 3, imagem 2 %32
    • Flip entire device upside down.
    • Remove two rubber coverings on the back of the device.
    Pergunte ao FixBot
    Comentar
  4. Capresso Infinity Timer/On Switch Replacement: passo 4, imagem 1 %32 Capresso Infinity Timer/On Switch Replacement: passo 4, imagem 2 %32
    • Remove four 11.59mm T10 screws.
    • The screws will have small circular washers under them. Put them aside for reassembly.
    Pergunte ao FixBot
    Comentar
  5. Capresso Infinity Timer/On Switch Replacement: passo 5, imagem 1 %32 Capresso Infinity Timer/On Switch Replacement: passo 5, imagem 2 %32 Capresso Infinity Timer/On Switch Replacement: passo 5, imagem 3 %32
    • Lift the metal outside casing off the black base.
    • Flip the outside casing forward so you have access to the inside of it.
    Pergunte ao FixBot
    Comentar
  6. Capresso Infinity Timer/On Switch Replacement: passo 6, imagem 1 %32 Capresso Infinity Timer/On Switch Replacement: passo 6, imagem 2 %32 Capresso Infinity Timer/On Switch Replacement: passo 6, imagem 3 %32
    • Remove one 11.59mm T10 screw.
    • Let the green wire fall, or place somewhere so it doesn't get in the way.
    • There will be a small metal retainer and washer, put them aside for reassembly.
    Pergunte ao FixBot
    Comentar
  7. Capresso Infinity Timer/On Switch Replacement: passo 7, imagem 1 %32 Capresso Infinity Timer/On Switch Replacement: passo 7, imagem 2 %32 Capresso Infinity Timer/On Switch Replacement: passo 7, imagem 3 %32
    • Remove two 11.59mm T10 screws.
    Pergunte ao FixBot
    Comentar
  8. Capresso Infinity Timer/On Switch Replacement: passo 8, imagem 1 %32 Capresso Infinity Timer/On Switch Replacement: passo 8, imagem 2 %32
    • Remove the time/on switch by pulling upwards.
    Pergunte ao FixBot
    Comentar
  9. Capresso Infinity Timer/On Switch Replacement, Timer/On Switch: passo 9, imagem 1 %32
    • Strip the two wires of their black covering connecting them to the black box.
    Pergunte ao FixBot
    Comentar
  10. Capresso Infinity Timer/On Switch Replacement: passo 10, imagem 1 %32 Capresso Infinity Timer/On Switch Replacement: passo 10, imagem 2 %32 Capresso Infinity Timer/On Switch Replacement: passo 10, imagem 3 %32
    • Solder the two cords holding in the blue and white wire in the black timer box.
    Pergunte ao FixBot
    Comentar
Conclusão
3 outras pessoas executaram este guia.
Melayne Spataro
Membro desde: 10/09/18
272 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team S1-G1, Leahy Fall 2018 Membro de USF Tampa, Team S1-G1, Leahy Fall 2018
USFT-LEAHY-F18S1G1
4 Membros
Autoria de 10 guias
7Comentários do guia
do you know where I can get a new black timer box?
geclay@hotmail.com - Responder Compartilhar
Where can I purchase a timer/on switch?
Rob Gordon - Responder Compartilhar
Same question here, where can I buy this part?
Dominic Daigle - Responder Compartilhar
Just piling on,has anyone found where to buy the Timer switch?
Chris DiNicolas - Responder Compartilhar
Same, looking for part number and/or where to buy the timer dial.
Hans Sorensen - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 12
Últimos 30 dias: 47
Ao todo: 3,693
