Ir para o conteúdo principal
Capresso Infinity Outside Casing Replacement
O que você precisa
  1. Capresso Infinity Outside Casing Replacement, Metal Outside Casing: passo 1, imagem 1 %32 Capresso Infinity Outside Casing Replacement, Metal Outside Casing: passo 1, imagem 2 %32
    • Twist the top plastic container to the left counterclockwise.
    • Pull upwards to remove.
    Pergunte ao FixBot
    Comentar
  2. Capresso Infinity Outside Casing Replacement: passo 2, imagem 1 %32 Capresso Infinity Outside Casing Replacement: passo 2, imagem 2 %32 Capresso Infinity Outside Casing Replacement: passo 2, imagem 3 %32
    • Twist the top burr to the left counter clockwise.
    Pergunte ao FixBot
    Comentar
  3. Capresso Infinity Outside Casing Replacement: passo 3, imagem 1 %32 Capresso Infinity Outside Casing Replacement: passo 3, imagem 2 %32
    • Flip entire device upside down.
    • Remove two rubber coverings on the back of the device.
    Pergunte ao FixBot
    Comentar
  4. Capresso Infinity Outside Casing Replacement: passo 4, imagem 1 %32 Capresso Infinity Outside Casing Replacement: passo 4, imagem 2 %32
    • Remove four 11.59mm T10 screws.
    • The screws will have small circular washers under them. Put them aside for reassembly.
    Pergunte ao FixBot
    Comentar
  5. Capresso Infinity Outside Casing Replacement: passo 5, imagem 1 %32 Capresso Infinity Outside Casing Replacement: passo 5, imagem 2 %32 Capresso Infinity Outside Casing Replacement: passo 5, imagem 3 %32
    • Lift the metal outside casing off the black base.
    • Flip the outside casing forward so you have access to the inside of it.
    Pergunte ao FixBot
    Comentar
  6. Capresso Infinity Outside Casing Replacement: passo 6, imagem 1 %32 Capresso Infinity Outside Casing Replacement: passo 6, imagem 2 %32 Capresso Infinity Outside Casing Replacement: passo 6, imagem 3 %32
    • Remove one 11.59mm T10 screw.
    • Let the green wire fall, or place somewhere so it doesn't get in the way.
    • There will be a small metal retainer and washer, put them aside for reassembly.
    Pergunte ao FixBot
    Comentar
  7. Capresso Infinity Outside Casing Replacement: passo 7, imagem 1 %32 Capresso Infinity Outside Casing Replacement: passo 7, imagem 2 %32 Capresso Infinity Outside Casing Replacement: passo 7, imagem 3 %32
    • Remove two 11.59mm T10 screws.
    Pergunte ao FixBot
    Comentar
  8. Capresso Infinity Outside Casing Replacement: passo 8, imagem 1 %32 Capresso Infinity Outside Casing Replacement: passo 8, imagem 2 %32
    • Remove the time/on switch by pulling upwards.
    Pergunte ao FixBot
    Comentar
Conclusão
Nina Mackin
Membro desde: 10/09/18
555 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team S1-G1, Leahy Fall 2018 Membro de USF Tampa, Team S1-G1, Leahy Fall 2018
USFT-LEAHY-F18S1G1
4 Membros
Autoria de 10 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 13
Últimos 30 dias: 35
Ao todo: 1,967
