Ir para o conteúdo principal
Canon Selphy CP910 Buttons Replacement
O que você precisa
  1. Canon Selphy CP910 Buttons Replacement, Disassembling Canon Selphy CP910 Body: passo 1, imagem 1 %32 Canon Selphy CP910 Buttons Replacement, Disassembling Canon Selphy CP910 Body: passo 1, imagem 2 %32
    • Turn the printer over.
    • Use the PH1 screw bit to remove the three 8 mm screws in the middle of the back plate.
    • Keep track of these screws because you will need them to reassemble the printer.
  2. Canon Selphy CP910 Buttons Replacement: passo 2, imagem 1 %32 Canon Selphy CP910 Buttons Replacement: passo 2, imagem 2 %32 Canon Selphy CP910 Buttons Replacement: passo 2, imagem 3 %32
    • Loosen up the four 10 mm corner screws.
    • A screwdriver with a long shaft approximately 7mm in diameter will make it easier to reach these screws.
  3. Canon Selphy CP910 Buttons Replacement: passo 3, imagem 1 %32 Canon Selphy CP910 Buttons Replacement: passo 3, imagem 2 %32 Canon Selphy CP910 Buttons Replacement: passo 3, imagem 3 %32
    • Turn the device around and remove the "open" lid.
    • This lid needs to be removed in order to take the printer apart.
    • Gently bend the lid and remove it from its hinges.
  4. Canon Selphy CP910 Buttons Replacement: passo 4, imagem 1 %32 Canon Selphy CP910 Buttons Replacement: passo 4, imagem 2 %32 Canon Selphy CP910 Buttons Replacement: passo 4, imagem 3 %32
    • Turn the device back over and lift the top panel up.
    • Disconnect the ribbon cables leading to the LCD screen.
    • Pull the top panel off.
  5. Canon Selphy CP910 Buttons Replacement, Buttons: passo 5, imagem 1 %32 Canon Selphy CP910 Buttons Replacement, Buttons: passo 5, imagem 2 %32
    • Turn the top panel over so the inside faces toward you.
  6. Canon Selphy CP910 Buttons Replacement: passo 6, imagem 1 %32 Canon Selphy CP910 Buttons Replacement: passo 6, imagem 2 %32 Canon Selphy CP910 Buttons Replacement: passo 6, imagem 3 %32
    • Use the PH0 screw bit to remove the five 10 mm screws located above the circuit board.
  7. Canon Selphy CP910 Buttons Replacement: passo 7, imagem 1 %32 Canon Selphy CP910 Buttons Replacement: passo 7, imagem 2 %32
    • Carefully remove the frame attached to the screen.
  8. Canon Selphy CP910 Buttons Replacement: passo 8, imagem 1 %32 Canon Selphy CP910 Buttons Replacement: passo 8, imagem 2 %32 Canon Selphy CP910 Buttons Replacement: passo 8, imagem 3 %32
    • Take out the circuit board.
    • Once you take out the circuit board, you should be left with just the case.
  9. Canon Selphy CP910 Buttons Replacement: passo 9, imagem 1 %32 Canon Selphy CP910 Buttons Replacement: passo 9, imagem 2 %32
    • There is a clear plastic “L” shaped piece that acts as the power light for the printer. The piece is not attached to the printer so take care not to lose it.
    • Remove the button framework and replace it with new one.
Conclusão
Equipe
UW Tacoma, Team 1-6, Rose Winter 2016 Membro de UW Tacoma, Team 1-6, Rose Winter 2016
UWT-ROSE-W16S1G6
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 15
Duração total: 797
