Ir para o conteúdo principal
Canon Selphy CP720 Screen Replacement
O que você precisa
  1. Canon Selphy CP720 Screen Replacement, Screen: passo 1, imagem 1 %32
    • Remove the three 6mm Phillips #1 screws.
    Pergunte ao FixBot
    Comentar
  2. Canon Selphy CP720 Screen Replacement: passo 2, imagem 1 %32 Canon Selphy CP720 Screen Replacement: passo 2, imagem 2 %32
    • Remove the four 8mm Phillips #1 screws, located in each corner of the device.
    Pergunte ao FixBot
    Comentar
  3. Canon Selphy CP720 Screen Replacement: passo 3, imagem 1 %32
    • Grasp one half of the device's shell in each hand, and pull them apart. They are connected, so don't separate them completely.
    Pergunte ao FixBot
    Comentar
  4. Canon Selphy CP720 Screen Replacement: passo 4, imagem 1 %32 Canon Selphy CP720 Screen Replacement: passo 4, imagem 2 %32
    • Lift the side panel off to expose the inside of the printer.
    Pergunte ao FixBot
    Comentar
  5. Canon Selphy CP720 Screen Replacement: passo 5, imagem 1 %32
    • Remove the four 8mm Phillips #00 screws that hold the upper circuit board to the shell.
    Pergunte ao FixBot
    Comentar
  6. Canon Selphy CP720 Screen Replacement: passo 6, imagem 1 %32
    • Remove two 8mm Phillips #00 screws from the yellow board.
    Pergunte ao FixBot
    Comentar
  7. Canon Selphy CP720 Screen Replacement: passo 7, imagem 1 %32
    • Remove the two 8mm Phillips #00 screws from the screen.
    • Lift off the circuit board, yellow board, and screen.
    Pergunte ao FixBot
    Comentar
  8. Canon Selphy CP720 Screen Replacement: passo 8, imagem 1 %32 Canon Selphy CP720 Screen Replacement: passo 8, imagem 2 %32 Canon Selphy CP720 Screen Replacement: passo 8, imagem 3 %32
    • To separate the screen from the circuit board, grasp the data ribbon cable near the base of the black connector on the circuit board and pull parallel to the surface of the board, toward the screen.
    Pergunte ao FixBot
    Comentar
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 7
Últimos 30 dias: 45
Ao todo: 772
