Introdução
The motherboard of the Canon Powershot Pro1 contains a large percentage of the camera’s circuitry. Damage to the motherboard can result in a variety of issues. This guide can help you replace your damaged motherboard.
Use care when removing the ribbon cables and connectors, and ensure you place connectors into their designated position.
O que você precisa
Locate the battery compartment cover on the right hand side of the camera. The cover features the text: “CF/BATT.OPEN”.
Ferramenta utilizada neste passo:Tweezers$4.99
Lift up the gold insulation cover to reveal the motherboard.
Use tweezers and an iFixit opening tool, detach any wire connectors and ribbon cables from the motherboard.
