Ir para o conteúdo principal
Canon Powershot A720 IS Shutter Button Replacement
O que você precisa
    1. Canon Powershot A720 IS Shutter Button Replacement, Shutter Button: passo 1, imagem 1 %32
      Ferramenta utilizada neste passo:
      • Carefully insert the tip of the tweezers in the space between the shutter button and the zoom dial. Gently insert the tip under the button and slowly lift.
      • If this step does not dislodge the shutter button, move on to step 2.
      • Do not force the tip of the tweezer or insert the tweezer too deep in between the shutter button and zoom dial. It will cause permanent cosmetic and button damage to the camera.
      Pergunte ao FixBot
      Comentar
    2. Canon Powershot A720 IS Shutter Button Replacement: passo 2, imagem 1 %32 Canon Powershot A720 IS Shutter Button Replacement: passo 2, imagem 2 %32
      • On the bottom of the camera, open the battery compartment by pushing the lock up. The door will then spring open allowing you to slide the batteries out.
      • If an SD card is also inserted, push on it to easily remove it from the camera.
      Pergunte ao FixBot
      Comentar
    3. Canon Powershot A720 IS Shutter Button Replacement: passo 3, imagem 1 %32 Canon Powershot A720 IS Shutter Button Replacement: passo 3, imagem 2 %32 Canon Powershot A720 IS Shutter Button Replacement: passo 3, imagem 3 %32
      • On the left side of the camera remove the two visible 4mm Phillips head screws.
      • On the right side of the camera remove the two visible 4mm Phillips head screws.
      • On the bottom of the camera remove the two visible 4mm Phillips head screws.
      Pergunte ao FixBot
      Comentar
    4. Canon Powershot A720 IS Shutter Button Replacement: passo 4, imagem 1 %32 Canon Powershot A720 IS Shutter Button Replacement: passo 4, imagem 2 %32 Canon Powershot A720 IS Shutter Button Replacement: passo 4, imagem 3 %32
      • Slowly and gently pry open the back case panel from the rest of the camera.
      • The gray rubber cover labeled DC IN DIGITAL A/V OUT may fall out.
      Pergunte ao FixBot
      Comentar
    5. Canon Powershot A720 IS Shutter Button Replacement: passo 5, imagem 1 %32
      • Remove the two 3 mm screws below the LCD screen using a Phillips #00 screwdriver.
      • Unscrew the top 4 mm Phillips head screw.
      Pergunte ao FixBot
      Comentar
    6. Canon Powershot A720 IS Shutter Button Replacement: passo 6, imagem 1 %32 Canon Powershot A720 IS Shutter Button Replacement: passo 6, imagem 2 %32
      • Gently turnover the LCD screen so that the motherboard is exposed.
      • Carefully pull the ribbon cable straight out using your thumb and index finger.
      • The ribbon cable is fragile and will break if bent too much.
      Pergunte ao FixBot
      Comentar
    7. Canon Powershot A720 IS Shutter Button Replacement: passo 7, imagem 1 %32 Canon Powershot A720 IS Shutter Button Replacement: passo 7, imagem 2 %32
      • Remove the 3mm Phillips head screw between the circuit boards.
      • Remove the three 3.5mm Phillips head screws on the circuit board.
      Pergunte ao FixBot
      Comentar
    8. Canon Powershot A720 IS Shutter Button Replacement: passo 8, imagem 1 %32 Canon Powershot A720 IS Shutter Button Replacement: passo 8, imagem 2 %32 Canon Powershot A720 IS Shutter Button Replacement: passo 8, imagem 3 %32
      • Remove the gray rubber cover labeled DC IN DIGITAL A/V OUT if it hasn't fallen out yet on its own.
      • Carefully pull the front panel away from the rest of the camera.
      Pergunte ao FixBot
      Comentar
    9. Canon Powershot A720 IS Shutter Button Replacement: passo 9, imagem 1 %32 Canon Powershot A720 IS Shutter Button Replacement: passo 9, imagem 2 %32
      • In the front panel remove the two 2.5mm Phillips head screws attached to the shutter button.
      • The shutter button and other components will fall out.
      Pergunte ao FixBot
      Comentar
Conclusão
Ismael R
Membro desde: 01/19/15
251 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 17-4, Watkins Winter 2015 Membro de USF Tampa, Team 17-4, Watkins Winter 2015
USFT-WATKINS-W15S17G4
3 Membros
Autoria de 8 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 33
Ao todo: 1,456
