Ir para o conteúdo principal
Canon PowerShot SX600 HS Display Screen Replacement
O que você precisa
  1. Canon PowerShot SX600 HS Display Screen Replacement, Battery: passo 1, imagem 1 %32
    • To remove the battery, locate the battery cover on the bottom of the camera.
    • Using your thumb, press down on the cover and slide it outwards.
    Pergunte ao FixBot
    Comentar
  2. Canon PowerShot SX600 HS Display Screen Replacement: passo 2, imagem 1 %32
    • Depress the orange lever holding the battery in place to unlock it.
    Pergunte ao FixBot
    Comentar
  3. Canon PowerShot SX600 HS Display Screen Replacement: passo 3, imagem 1 %32 Canon PowerShot SX600 HS Display Screen Replacement: passo 3, imagem 2 %32
    • Use your fingers to remove the battery.
    • Be sure to remember the alignment of the nodes for reassembly.
    Pergunte ao FixBot
    Comentar
  4. Canon PowerShot SX600 HS Display Screen Replacement, Power and Shutter Buttons: passo 4, imagem 1 %32
    • Use a #000 Phillips screwdriver to unscrew the four 4mm screws located on the sides of the camera (2 for each side).
    Pergunte ao FixBot
    Comentar
  5. Canon PowerShot SX600 HS Display Screen Replacement: passo 5, imagem 1 %32
    • Unscrew the four 2mm located on the bottom of the camera using a Phillips #000 screwdriver.
    Pergunte ao FixBot
    Comentar
  6. Canon PowerShot SX600 HS Display Screen Replacement: passo 6, imagem 1 %32
    • Use a plastic opening tool to loosen and remove both the front and back plates of the camera, as well as the two side pieces.
    Pergunte ao FixBot
    Comentar
  7. Canon PowerShot SX600 HS Display Screen Replacement: passo 7, imagem 1 %32 Canon PowerShot SX600 HS Display Screen Replacement: passo 7, imagem 2 %32
    • Unscrew the three 2mm screws attaching the piece to the camera frame with a #000 Phillips screwdriver.
    Pergunte ao FixBot
    Comentar
  8. Canon PowerShot SX600 HS Display Screen Replacement: passo 8, imagem 1 %32
    • Use an opening tool to gently remove the power and shutter button assembly from the frame.
    Pergunte ao FixBot
    Comentar
  9. Canon PowerShot SX600 HS Display Screen Replacement, Display Screen: passo 9, imagem 1 %32 Canon PowerShot SX600 HS Display Screen Replacement, Display Screen: passo 9, imagem 2 %32
    • Unscrew the 2mm screw connections of the main board protector from the camera frame using a #000 Phillips head screwdriver (2 on front, 1 on top)
    Pergunte ao FixBot
    Comentar
  10. Canon PowerShot SX600 HS Display Screen Replacement: passo 10, imagem 1 %32
    • Use a Phillips #000 screwdriver to unscrew the 4mm screw.
    Pergunte ao FixBot
    Comentar
  11. Canon PowerShot SX600 HS Display Screen Replacement: passo 11, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Use a pair of tweezers to remove the no-fuss connector from its holder.
    Pergunte ao FixBot
    Comentar
  12. Canon PowerShot SX600 HS Display Screen Replacement: passo 12, imagem 1 %32
    • Gently lift the protector from the frame.
    Pergunte ao FixBot
    Comentar
  13. Canon PowerShot SX600 HS Display Screen Replacement: passo 13, imagem 1 %32
    • Lift the LCD screen ZIF connector tab and remove the ribbon cable.
    • Detach the no-fuss connector.
    • Lift the screen from its holder.
    Pergunte ao FixBot
    Comentar
Conclusão
7 outras pessoas executaram este guia.
Equipe
USF Tampa, Team S6-G4, Lacy Spring 2017 Membro de USF Tampa, Team S6-G4, Lacy Spring 2017
USFT-LACY-S17S6G4
3 Membros
Autoria de 9 guias
2Comentários do guia
Plz I want othe
Gihan - Responder Compartilhar
I did all this with a new LCD. After reassemble the lens has extended out but camera does not turn on. Should I take it apart again and start from beginning. Is there a connector not in place correctly that will cause this to happen?
Bill Graham - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 21
Últimos 30 dias: 63
Ao todo: 5,880
