Ir para o conteúdo principal
Canon PowerShot SX60 HS Back Panel Replacement
O que você precisa
  1. Canon PowerShot SX60 HS Back Panel Replacement, Back Panel: passo 1, imagem 1 %32
    • Make sure to power off the device before completing any more steps.
    • Remove the battery by releasing the orange clip in the battery compartment.
    Pergunte ao FixBot
    Comentar
  2. Canon PowerShot SX60 HS Back Panel Replacement: passo 2, imagem 1 %32 Canon PowerShot SX60 HS Back Panel Replacement: passo 2, imagem 2 %32
    • Remove the rubber eye piece by pulling it back.
    • Use the Phillips #00 screwdriver to remove the two 5mm #00 screws located on the side of the viewfinder.
    Pergunte ao FixBot
    Comentar
  3. Canon PowerShot SX60 HS Back Panel Replacement: passo 3, imagem 1 %32 Canon PowerShot SX60 HS Back Panel Replacement: passo 3, imagem 2 %32
    • Use the Phillips #00 screwdriver to remove the 4mm #00 screw located on the bottom left of the device.
    • Use the Phillips #00 screwdriver to remove the 5mm #00 screw located on the bottom center of the device.
    • Use the Phillips #00 screwdriver to remove the 7mm #00 screw on the right top corner of the camera, just above the media ports.
    • Use the Phillips #00 screwdriver to remove the two 5mm #00 screws located on the right side, under the media port dust cover.
    Pergunte ao FixBot
    Comentar
  4. Canon PowerShot SX60 HS Back Panel Replacement: passo 4, imagem 1 %32 Canon PowerShot SX60 HS Back Panel Replacement: passo 4, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Ensure the LCD screen is swung fully to the left before taking off the back panel.
    • Use the iFixit opening tool to pry off the back panel.
    • Don't completely pull off the back panel because there is still a ribbon attached.
    • Use the black spudger to unclip the ribbon located behind the battery compartment. Then remove it using the nylon tipped tweezers.
    • Once the ribbon is unplugged, remove the back panel from the camera body.
    Pergunte ao FixBot
    Comentar
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 36
Ao todo: 1,144
