Ir para o conteúdo principal
Canon PowerShot SX520 HS Lens Replacement
O que você precisa
    1. Canon PowerShot SX520 HS Lens Replacement, Battery: passo 1, imagem 1 %32
      • Using your fingers, slide the battery compartment door to the right until it unlocks.
      Pergunte ao FixBot
      Comentar
    2. Canon PowerShot SX520 HS Lens Replacement: passo 2, imagem 1 %32
      • Rotate the door along hinges to open.
      • Take out the battery with your fingers.
      Pergunte ao FixBot
      Comentar
    1. Canon PowerShot SX520 HS Lens Replacement, Back Face: passo 3, imagem 1 %32 Canon PowerShot SX520 HS Lens Replacement, Back Face: passo 3, imagem 2 %32 Canon PowerShot SX520 HS Lens Replacement, Back Face: passo 3, imagem 3 %32
      • Remove 2-3.4 mm screws that secure the back panel using a Phillips #000 screwdriver.
      • Remove 4-4 mm screws on the left and right sides of the camera using a Phillips #000 screwdriver.
      Pergunte ao FixBot
      Comentar
    2. Canon PowerShot SX520 HS Lens Replacement: passo 4, imagem 1 %32
      • Remove 2-4 mm screws that secure the bottom of the camera using a Phillips #000 screwdriver.
      Pergunte ao FixBot
      Comentar
    3. Canon PowerShot SX520 HS Lens Replacement: passo 5, imagem 1 %32 Canon PowerShot SX520 HS Lens Replacement: passo 5, imagem 2 %32
      • Pull back the rubber facing to access the A/V and HDMI output compartment.
      • Remove 1-3.4mm screw inside the compartment using a Phillips #000 screwdriver.
      Pergunte ao FixBot
      Comentar
    4. Canon PowerShot SX520 HS Lens Replacement: passo 6, imagem 1 %32
      • Once all screws are removed, pull the back facing off with your fingers.
      Pergunte ao FixBot
      Comentar
    1. Canon PowerShot SX520 HS Lens Replacement, LCD Screen: passo 7, imagem 1 %32
      • Remove 3-4.4 mm screws that secure the small metal plate using a Phillips #000 screwdriver.
      Pergunte ao FixBot
      Comentar
    2. Canon PowerShot SX520 HS Lens Replacement: passo 8, imagem 1 %32
      • Carefully pop out the LCD screen with your fingers.
      Pergunte ao FixBot
      Comentar
    1. Canon PowerShot SX520 HS Lens Replacement, Metal Plate: passo 9, imagem 1 %32 Canon PowerShot SX520 HS Lens Replacement, Metal Plate: passo 9, imagem 2 %32 Canon PowerShot SX520 HS Lens Replacement, Metal Plate: passo 9, imagem 3 %32
      • Remove 6-4.4 mm screws that secure the metal cover using a Phillips #000 screwdriver.
      • Remove 2-2.5 mm screws that secure the back panel using a Phillips #000 screwdriver.
      • After all 8 screws are removed, pull the metal plate out with your fingers.
      Pergunte ao FixBot
      Comentar
    1. Canon PowerShot SX520 HS Lens Replacement, Lens: passo 10, imagem 1 %32
      • Unlcip the large cable by pulling up on the metal part with your finger.
      • Slide out the 2 smaller cables with your fingers.
      Pergunte ao FixBot
      Comentar
    2. Canon PowerShot SX520 HS Lens Replacement: passo 11, imagem 1 %32
      • Lift up the lens by grabbing the sides with your fingers.
      Pergunte ao FixBot
      Comentar
Conclusão
6 outras pessoas executaram este guia.
Lisa Choe
Membro desde: 09/22/15
460 Reputação
Autoria de 3 guias
Equipe
Baylor, Team 4-4, Williams Fall 2015 Membro de Baylor, Team 4-4, Williams Fall 2015
BU-WILLIAMS-F15S4G4
4 Membros
Autoria de 6 guias
1Comentário do guia
guide is unfinished; dropping to the point of lens group extraction without going on further. I found it, useless.
SimoneGallina - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 12
Últimos 30 dias: 47
Ao todo: 3,793
