Ir para o conteúdo principal
Canon PowerShot SX160 IS Shutter Button Replacement
O que você precisa
    1. Canon PowerShot SX160 IS Shutter Button Replacement, Shutter Button: passo 1, imagem 1 %32 Canon PowerShot SX160 IS Shutter Button Replacement, Shutter Button: passo 1, imagem 2 %32 Canon PowerShot SX160 IS Shutter Button Replacement, Shutter Button: passo 1, imagem 3 %32
      • Unscrew 2-4.8mm black screws from the front of the camera using a #0 Phillips screwdriver.
      • Unscrew 2-4.8mm black screws from the side of the camera using a #0 Phillips screwdriver.
      • Unscrew 2-4.8mm black screws from the bottom of the camera using a #0 Phillips screwdriver.
      Pergunte ao FixBot
      Comentar
    2. Canon PowerShot SX160 IS Shutter Button Replacement: passo 2, imagem 1 %32 Canon PowerShot SX160 IS Shutter Button Replacement: passo 2, imagem 2 %32
      • Using your hands, gently separate the back panel from the camera.
      • Continue to pull the back panel until it completely detaches from the camera.
      Pergunte ao FixBot
      Comentar
    3. Canon PowerShot SX160 IS Shutter Button Replacement: passo 3, imagem 1 %32 Canon PowerShot SX160 IS Shutter Button Replacement: passo 3, imagem 2 %32
      • Use your hands to gently separate the front panel from the camera.
      • Continue to pull the front panel until it completely detaches from the camera.
      Pergunte ao FixBot
      Comentar
    4. Canon PowerShot SX160 IS Shutter Button Replacement: passo 4, imagem 1 %32
      • Locate and replace the shutter button on the front panel of the camera.
      Pergunte ao FixBot
      Comentar
Conclusão
Congratulations, you have successfully replaced your shutter button. To reassemble your device, follow these instructions in reverse order.
Jamie Secretan
Membro desde: 03/11/15
2.018 Reputação
Autoria de 6 guias
Equipe
2Comentários do guia
Great guide on how to replace the shutter button. Where can I get the new button?
mess857 - Responder Compartilhar
did you ever figure out where to get a new button?
christinapayne1@icloud.com - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 70
Ao todo: 3,870
