Ir para o conteúdo principal
Canon PowerShot SX160 IS Format Wheel Replacement
O que você precisa
    1. Canon PowerShot SX160 IS Format Wheel Replacement, Format Wheel: passo 1, imagem 1 %32 Canon PowerShot SX160 IS Format Wheel Replacement, Format Wheel: passo 1, imagem 2 %32
      • Use a #0 phillips screwdriver to unscrew the two black 4.8mm phillips head screws from the back of the camera.
      • The screws are located directly above the LCD screen.
      Pergunte ao FixBot
      Comentar
    2. Canon PowerShot SX160 IS Format Wheel Replacement: passo 2, imagem 1 %32 Canon PowerShot SX160 IS Format Wheel Replacement: passo 2, imagem 2 %32
      • Use a #0 phillips screwdriver to unscrew the two black 4.8mm phillips head screws from the side of the camera.
      • Use a #0 phillips screwdriver to unscrew the two black 4.8mm phillips head screws from the bottom of the camera.
      Pergunte ao FixBot
      Comentar
    3. Canon PowerShot SX160 IS Format Wheel Replacement: passo 3, imagem 1 %32 Canon PowerShot SX160 IS Format Wheel Replacement: passo 3, imagem 2 %32
      • Use your hands to gently separate the back plate from the camera.
      • Slowly pull off the camera plate until it fully detaches from the camera.
      Pergunte ao FixBot
      Comentar
    4. Canon PowerShot SX160 IS Format Wheel Replacement: passo 4, imagem 1 %32 Canon PowerShot SX160 IS Format Wheel Replacement: passo 4, imagem 2 %32
      • Use your hands to gently separate the front plate from the camera.
      Pergunte ao FixBot
      Comentar
    5. Canon PowerShot SX160 IS Format Wheel Replacement: passo 5, imagem 1 %32
      • Locate and replace the format wheel on the front panel of the camera.
      Pergunte ao FixBot
      Comentar
Conclusão
Congratulations, you have successfully replaced your format wheel. To reassemble your device, follow these instructions in reverse order.
Jamie Secretan
Membro desde: 03/11/15
2.018 Reputação
Autoria de 6 guias
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 33
Ao todo: 1,049
