Ir para o conteúdo principal
Canon PowerShot SX150 IS Buttons Replacement
O que você precisa
    1. Canon PowerShot SX150 IS Buttons Replacement, Canon PowerShot SX150 IS Battery Removal: passo 1, imagem 1 %32 Canon PowerShot SX150 IS Buttons Replacement, Canon PowerShot SX150 IS Battery Removal: passo 1, imagem 2 %32 Canon PowerShot SX150 IS Buttons Replacement, Canon PowerShot SX150 IS Battery Removal: passo 1, imagem 3 %32
      • Locate the battery cover on the bottom of the camera.
      • Slide the battery compartment cover the direction the arrow is pointing to open the compartment.
      • Remove batteries.
      Pergunte ao FixBot
      Comentar
    1. Canon PowerShot SX150 IS Buttons Replacement, Buttons: passo 2, imagem 1 %32 Canon PowerShot SX150 IS Buttons Replacement, Buttons: passo 2, imagem 2 %32 Canon PowerShot SX150 IS Buttons Replacement, Buttons: passo 2, imagem 3 %32
      • Remove the two, 2mm screws from the top of the screen. Using the J000 screwdriver.
      • Remove the 3, 5mm screws on either side of the camera. continue to use the same screwdriver from step 1.
      Pergunte ao FixBot
      Comentar
    2. Canon PowerShot SX150 IS Buttons Replacement: passo 3, imagem 1 %32
      • Remove the two, 4mm screws from the bottom of the camera. Continue using the same screwdriver from step 1.
      Pergunte ao FixBot
      Comentar
    3. Canon PowerShot SX150 IS Buttons Replacement: passo 4, imagem 1 %32
      • Remove back plate from the camera and locate the orange button plate to the right of the screen.
      Pergunte ao FixBot
      Comentar
    4. Canon PowerShot SX150 IS Buttons Replacement: passo 5, imagem 1 %32 Canon PowerShot SX150 IS Buttons Replacement: passo 5, imagem 2 %32 Canon PowerShot SX150 IS Buttons Replacement: passo 5, imagem 3 %32
      Ferramenta utilizada neste passo:
      • Once the back plate is removed. Locate the buttons to the right of the screen.
      • Using the tweezers carefully lift up the tabs connecting the buttons to the button plate.
      • After lifting the tabs the buttons should come right off, then replace with the new button.
      Pergunte ao FixBot
      Comentar
Conclusão
1Comentário do guia
Where do you buy replacement buttons/parts. Canon offers service but i don’t see parts?
robert jones - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 9
Últimos 30 dias: 27
Ao todo: 958
