Ir para o conteúdo principal
Canon PowerShot SD960 IS Battery Replacement
    1. Canon PowerShot SD960 IS Battery Replacement, Battery: passo 1, imagem 1 %32
      • Turn the camera over so that the bottom of the camera is facing up.
      Pergunte ao FixBot
      Comentar
    2. Canon PowerShot SD960 IS Battery Replacement: passo 2, imagem 1 %32 Canon PowerShot SD960 IS Battery Replacement: passo 2, imagem 2 %32
      • Apply slight pressure to the battery door and slide your finger over the release button in the direction of the arrows to open the battery door.
      • The battery door will open, allowing you to access the battery.
      Pergunte ao FixBot
      Comentar
    3. Canon PowerShot SD960 IS Battery Replacement: passo 3, imagem 1 %32
      • Push the the orange battery lock back to release the battery.
      • Remove the battery.
      Pergunte ao FixBot
      Comentar
Conclusão
1Comentário do guia
What battery does it use?
Arianna C - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 24
Ao todo: 847
