Ir para o conteúdo principal
Canon PowerShot SD1400 IS User Interface Panel Replacement
O que você precisa
    1. Canon PowerShot SD1400 IS User Interface Panel Replacement, User Interface Panel: passo 1, imagem 1 %32 Canon PowerShot SD1400 IS User Interface Panel Replacement, User Interface Panel: passo 1, imagem 2 %32 Canon PowerShot SD1400 IS User Interface Panel Replacement, User Interface Panel: passo 1, imagem 3 %32
      • Remove the four 2.0 mm Phillips screws of the camera using the J00 bit from the 54-bit Driver Kit. There are two screws on both sides.
      Pergunte ao FixBot
      Comentar
    2. Canon PowerShot SD1400 IS User Interface Panel Replacement: passo 2, imagem 1 %32
      • Remove the 4.0 mm Phillips screw located on the bottom of the camera.
      Pergunte ao FixBot
      Comentar
    3. Canon PowerShot SD1400 IS User Interface Panel Replacement: passo 3, imagem 1 %32
      • Remove the front face panel of the camera by hand using firm pressure.
      • If one point of the face is stuck to the body, check if there is a screw preventing the front face from coming off.
      Pergunte ao FixBot
      Comentar
    4. Canon PowerShot SD1400 IS User Interface Panel Replacement: passo 4, imagem 1 %32
      • Remove the rear panel of the camera by hand using firm pressure.
      Pergunte ao FixBot
      Comentar
    5. Canon PowerShot SD1400 IS User Interface Panel Replacement: passo 5, imagem 1 %32
      • Remove the user interface panel by hand. The panel may fall out on its own, this is normal.
      • Replace the user interface panel by setting it in position.
      Pergunte ao FixBot
      Comentar
Conclusão
Braxton Beal
Membro desde: 01/30/18
702 Reputação
Autoria de 3 guias
Equipe
Baylor, Team S1-G3, Johnson Spring 2018 Membro de Baylor, Team S1-G3, Johnson Spring 2018
BU-JOHNSON-S18S1G3
3 Membros
Autoria de 4 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 21
Ao todo: 640
