Ir para o conteúdo principal
Canon PowerShot S500 LCD Replacement
O que você precisa
    1. Canon PowerShot S500 LCD Replacement, Front and Rear Casing : passo 1, imagem 1 %32 Canon PowerShot S500 LCD Replacement, Front and Rear Casing : passo 1, imagem 2 %32
      • Unscrew five Phillips screws using a #0 Phillips screwdriver.
      • One screw is on upper right corner of the back panel.
      • The other four screws are on the bottom of the camera.
      Pergunte ao FixBot
      Comentar
    2. Canon PowerShot S500 LCD Replacement: passo 2, imagem 1 %32
      • Open the memory card cover by moving the slide switch toward the top end of of the camera.
      • Remove the memory card from the slot.
      Pergunte ao FixBot
      Comentar
    3. Canon PowerShot S500 LCD Replacement: passo 3, imagem 1 %32
      • Remove the rear cover from the rest of the camera.
      • This may require gentle rocking of the case to free it.
      Pergunte ao FixBot
      Comentar
    4. Canon PowerShot S500 LCD Replacement: passo 4, imagem 1 %32 Canon PowerShot S500 LCD Replacement: passo 4, imagem 2 %32
      • Unscrew the four Phillips screws from the side of the casing and one screw from the bottom using a #0 Phillips screwdriver.
      Pergunte ao FixBot
      Comentar
    5. Canon PowerShot S500 LCD Replacement: passo 5, imagem 1 %32
      • Free the front cover from the rest of the camera.
      • The cover may require gentle rocking to remove.
      Pergunte ao FixBot
      Comentar
    1. Canon PowerShot S500 LCD Replacement, LCD: passo 6, imagem 1 %32
      • Unscrew two Phillips screws above the LCD using a #0 Phillips screwdriver.
      Pergunte ao FixBot
      Comentar
    2. Canon PowerShot S500 LCD Replacement: passo 7, imagem 1 %32
      • Gently separate the top of LCD from the rest of the camera using your thumb.
      • Be careful not pull the LCD too far because of the ribbon cable connection.
      • Place the Spudger in the hole of the electrical ribbon.
      • Gently pull the ribbon down using the Spudger until it is free from the camera but still connected to the LCD.
      • The LCD will still be connected to the rest of the camera
      Pergunte ao FixBot
      Comentar
    3. Canon PowerShot S500 LCD Replacement: passo 8, imagem 1 %32 Canon PowerShot S500 LCD Replacement: passo 8, imagem 2 %32
      • Unscrew single Phillips screw with a #0 Phillips screwdriver.
      • Free the bottom panel and attached ribbon from the rest of the camera.
      • Be careful not to damage the ribbon.
      Pergunte ao FixBot
      Comentar
    4. Canon PowerShot S500 LCD Replacement: passo 9, imagem 1 %32
      • Turn over the camera.
      • Lift the clear plastic from the face of the camera, peeling the adhesive just below the zoom lens.
      • The plastic will still be connected on the left side.
      Pergunte ao FixBot
      Comentar
    5. Canon PowerShot S500 LCD Replacement: passo 10, imagem 1 %32
      • Place the Spudger between the orange ribbon and the black ribbon gate.
      • Lift the ribbon gate using the Spudger.
      Pergunte ao FixBot
      Comentar
    6. Canon PowerShot S500 LCD Replacement: passo 11, imagem 1 %32
      • Place the Spudger in the corner of the ribbon above the hole.
      • Remove the ribbon from the ribbon gate by pulling the Spudger away from the gate.
      Pergunte ao FixBot
      Comentar
    7. Canon PowerShot S500 LCD Replacement: passo 12, imagem 1 %32
      • Free this ribbon and the bottom panel from the rest of the camera.
      Pergunte ao FixBot
      Comentar
    8. Canon PowerShot S500 LCD Replacement: passo 13, imagem 1 %32
      • Turn the camera over so you can see the LCD.
      • Remove single Phillips screw below the LCD using a #0 Phillips screwdriver.
      Pergunte ao FixBot
      Comentar
    9. Canon PowerShot S500 LCD Replacement: passo 14, imagem 1 %32
      • Lift the blue ribbon gate using the Spudger.
      Pergunte ao FixBot
      Comentar
    10. Canon PowerShot S500 LCD Replacement: passo 15, imagem 1 %32
      • Insert the Spudger into the hole of the ribbon.
      • Move the Spudger away from the gate to fully remove ribbon.
      Pergunte ao FixBot
      Comentar
    11. Canon PowerShot S500 LCD Replacement: passo 16, imagem 1 %32
      • Lift the LCD away from the rest of the camera.
      Pergunte ao FixBot
      Comentar
Conclusão
Nathan Balcom
Membro desde: 01/21/10
102 Reputação
Autoria de 8 guias
Equipe
Cal Poly, Team 16-28, Maness Winter 2010 Membro de Cal Poly, Team 16-28, Maness Winter 2010
CPSU-MANESS-W10S16G28
4 Membros
Autoria de 9 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 6
Últimos 30 dias: 33
Ao todo: 3,676
