Ir para o conteúdo principal
Canon PowerShot G16 Lens Replacement
O que você precisa
  1. Canon PowerShot G16 Lens Replacement, Battery: passo 1, imagem 1 %32 Canon PowerShot G16 Lens Replacement, Battery: passo 1, imagem 2 %32 Canon PowerShot G16 Lens Replacement, Battery: passo 1, imagem 3 %32
    • Open the battery flap on the bottom of the camera by applying pressure and pushing in the direction of the arrow.
    • Remove your finger and allow the flap to pop open.
    Pergunte ao FixBot
    Comentar
  2. Canon PowerShot G16 Lens Replacement: passo 2, imagem 1 %32 Canon PowerShot G16 Lens Replacement: passo 2, imagem 2 %32 Canon PowerShot G16 Lens Replacement: passo 2, imagem 3 %32
    • Push the brown lever so that it pivots counterclockwise.
    • Grip and remove the battery.
    Pergunte ao FixBot
    Comentar
  3. Canon PowerShot G16 Lens Replacement, Button Circuit Board: passo 3, imagem 1 %32 Canon PowerShot G16 Lens Replacement, Button Circuit Board: passo 3, imagem 2 %32 Canon PowerShot G16 Lens Replacement, Button Circuit Board: passo 3, imagem 3 %32
    • Remove the ring around the lens by simultaneously pressing the black button located at the bottom right of the ring and rotating the ring counterclockwise.
    Pergunte ao FixBot
    Comentar
  4. Canon PowerShot G16 Lens Replacement: passo 4, imagem 1 %32
    • Remove the four 3.3 mm screws on the bottom of the camera using a Phillips #00 screwdriver.
    Pergunte ao FixBot
    Comentar
  5. Canon PowerShot G16 Lens Replacement: passo 5, imagem 1 %32
    • Remove the 3.3 mm screw on the right side of the viewfinder using a Phillips #00 screwdriver.
    Pergunte ao FixBot
    Comentar
  6. Canon PowerShot G16 Lens Replacement: passo 6, imagem 1 %32
    • Remove the two 3.3 mm screws near the speaker using a Phillips #00 screwdriver.
    Pergunte ao FixBot
    Comentar
  7. Canon PowerShot G16 Lens Replacement: passo 7, imagem 1 %32
    • Open the port cover by lifting up the tab with your finger and remove the 7.3 mm screw underneath the cover using a Phillips #00 screwdriver.
    • Remove the other 3.3 mm screw below the ports using a Phillips #00 screwdriver.
    Pergunte ao FixBot
    Comentar
  8. Canon PowerShot G16 Lens Replacement: passo 8, imagem 1 %32 Canon PowerShot G16 Lens Replacement: passo 8, imagem 2 %32
    • Using your fingers, carefully pull the the back cover off by grabbing the bottom left of the back cover and pulling outwards.
    Pergunte ao FixBot
    Comentar
  9. Canon PowerShot G16 Lens Replacement: passo 9, imagem 1 %32
    • Using your fingers, carefully pry the front cover off starting at the bottom right.
    Pergunte ao FixBot
    Comentar
  10. Canon PowerShot G16 Lens Replacement: passo 10, imagem 1 %32 Canon PowerShot G16 Lens Replacement: passo 10, imagem 2 %32
    • Remove the 3.8 mm screw at the bottom right of the port cover housing using a Phillips #00 screwdriver.
    • Lift away the port cover housing.
    Pergunte ao FixBot
    Comentar
  11. Canon PowerShot G16 Lens Replacement: passo 11, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Reorient the camera so that you are looking at the back.
    • Make sure to pull the connector straight down as pulling up may cause harm to the connector.
    • Unplug the button circuit board from the motherboard by unlocking the ZIF connector (gently lift the brown lock that keeps the cable in place).
    • Pull the connector downwards with the tweezers.
    Pergunte ao FixBot
    Comentar
  12. Canon PowerShot G16 Lens Replacement: passo 12, imagem 1 %32
    • Remove the 3.0 mm screw on the top of the button memory board using a Phillips #00 screwdriver.
    • Remove the 2.8 mm screw on the bottom of the button memory board using a Phillips #00 screwdriver.
    Pergunte ao FixBot
    Comentar
  13. Canon PowerShot G16 Lens Replacement: passo 13, imagem 1 %32
    • Lift the button circuit board away from the camera.
    Pergunte ao FixBot
    Comentar
  14. Canon PowerShot G16 Lens Replacement, LCD: passo 14, imagem 1 %32 Canon PowerShot G16 Lens Replacement, LCD: passo 14, imagem 2 %32 Canon PowerShot G16 Lens Replacement, LCD: passo 14, imagem 3 %32
    • Do not pull the connector upwards as doing so may harm the connector housing.
    • Unlock the ZIF connector for the large connector ribbon by lifting up on the brown flap with the plastic opening tool.
    • Gently pull the connector straight out of the housing with your fingers.
    Pergunte ao FixBot
    Comentar
  15. Canon PowerShot G16 Lens Replacement: passo 15, imagem 1 %32 Canon PowerShot G16 Lens Replacement: passo 15, imagem 2 %32
    • Unplug the small connector ribbon by pulling the cable outwards from the camera using a spudger or your fingers.
    Pergunte ao FixBot
    Comentar
  16. Canon PowerShot G16 Lens Replacement: passo 16, imagem 1 %32
    • Be careful of the copper plate that may fall out once you lift the LCD screen away.
    • Gently lift the LCD away from the camera housing.
    Pergunte ao FixBot
    Comentar
  17. Canon PowerShot G16 Lens Replacement, Motherboard: passo 17, imagem 1 %32 Canon PowerShot G16 Lens Replacement, Motherboard: passo 17, imagem 2 %32
    • Be careful not to bend the EMI shield.
    • Lift and remove the copper EMI shield.
    Pergunte ao FixBot
    Comentar
  18. Canon PowerShot G16 Lens Replacement: passo 18, imagem 1 %32
    • Reorient the camera so that you are looking at the front.
    • Remove the 2.8 mm screw right above the screw holding the lens on using a Phillips #00 screwdriver.
    • Remove the 3.3 mm black screw to the left of the front viewfinder using a Phillips #000 screwdriver.
    Pergunte ao FixBot
    Comentar
  19. Canon PowerShot G16 Lens Replacement: passo 19, imagem 1 %32
    • Remove the 6.8 mm screw to the left of the rear viewfinder using a Phillips #00 screwdriver.
    • Remove the 5.2 mm screw to the right of the rear viewfinder using a Phillips #00 screwdriver.
    Pergunte ao FixBot
    Comentar
  20. Canon PowerShot G16 Lens Replacement: passo 20, imagem 1 %32 Canon PowerShot G16 Lens Replacement: passo 20, imagem 2 %32
    • Remove the top 2.3 mm screw from the side with the ports using a Phillips #00 screwdriver.
    • Remove the 4 mm screw right below the one you just removed using a Phillips #00 screwdriver.
    Pergunte ao FixBot
    Comentar
  21. Canon PowerShot G16 Lens Replacement: passo 21, imagem 1 %32 Canon PowerShot G16 Lens Replacement: passo 21, imagem 2 %32
    • Reorient the camera so that you are looking at the back of the camera.
    • Remove the rear viewfinder casing by firmly gripping it and pulling it out bottom first.
    • When reassembling, make sure that the viewfinder is fitted correctly beneath the top cover.
    Pergunte ao FixBot
    Comentar
  22. Canon PowerShot G16 Lens Replacement: passo 22, imagem 1 %32
    • Remove the newly uncovered 2.8 mm screw from the right of the viewfinder using a Phillips #00 screwdriver.
    • Remove the 4.9 mm screw from top right of the metal casing on the back using a Phillips #00 screwdriver.
    • Remove the 4.3 mm screw from bottom right of the metal casing on the back using a Phillips #00 screwdriver.
    • Remove the newly uncovered screws from the right of the viewfinder using a Phillips #00 screwdriver. (Note, they're already removed on the picture)
    Pergunte ao FixBot
    Comentar
  23. Canon PowerShot G16 Lens Replacement: passo 23, imagem 1 %32
    • Remove the 2.7 mm screw from the bottom of the camera using a Phillips #00 screwdriver.
    Pergunte ao FixBot
    Comentar
  24. Canon PowerShot G16 Lens Replacement: passo 24, imagem 1 %32
    • Reorient the camera so that you are looking at the side with the black felt circle.
    • Use caution around this black felt covered circle that is right below the screw to be removed. This is the speaker and can easily be damaged if pressed too hard or poked with a screwdriver.
    • Remove the 2.8 mm screw from the right side of the camera if you are looking at the front lens using a Phillips #00 screwdriver.
    Pergunte ao FixBot
    Comentar
  25. Canon PowerShot G16 Lens Replacement: passo 25, imagem 1 %32
    • Remove the metal casing from the back by lifting it away from the camera.
    Pergunte ao FixBot
    Comentar
  26. Canon PowerShot G16 Lens Replacement: passo 26, imagem 1 %32
    • Disconnect the cable on the top of the motherboard by lifting it up vertically using a plastic opening tool.
    Pergunte ao FixBot
    Comentar
  27. Canon PowerShot G16 Lens Replacement: passo 27, imagem 1 %32 Canon PowerShot G16 Lens Replacement: passo 27, imagem 2 %32
    • Disconnect the cable on the back of the camera to the left of the viewfinder by lifting it up vertically using a plastic opening tool.
    Pergunte ao FixBot
    Comentar
  28. Canon PowerShot G16 Lens Replacement: passo 28, imagem 1 %32 Canon PowerShot G16 Lens Replacement: passo 28, imagem 2 %32
    • Remove the top portion of the casing by firmly grasping it and pulling it upward to lift it off.
    • Some force may be required, but be careful to not bend either side of the top casing up too much or you will damage it.
    Pergunte ao FixBot
    Comentar
  29. Canon PowerShot G16 Lens Replacement: passo 29, imagem 1 %32 Canon PowerShot G16 Lens Replacement: passo 29, imagem 2 %32 Canon PowerShot G16 Lens Replacement: passo 29, imagem 3 %32
    • Open the two ZIF connectors by flipping them up using a plastic opening tool on the motherboard.
    • Make sure to pull the cable ribbon straight out and not up because pulling it up may harm the connector.
    • Be careful not to pinch the cable while pulling it out because it can easily be damaged if pinched. It is helpful to pull it out by the tabs that are built into the connector ribbon.
    • Disconnect the two cable ribbons by pulling them straight out.
    Pergunte ao FixBot
    Comentar
  30. Canon PowerShot G16 Lens Replacement: passo 30, imagem 1 %32 Canon PowerShot G16 Lens Replacement: passo 30, imagem 2 %32
    • Disconnect the lens cable from the motherboard by lifting it up vertically from the motherboard using a plastic opening tool.
    Pergunte ao FixBot
    Comentar
  31. Canon PowerShot G16 Lens Replacement: passo 31, imagem 1 %32 Canon PowerShot G16 Lens Replacement: passo 31, imagem 2 %32
    • Be careful not to pinch the cable while pulling it out because it can easily be damaged. It is helpful to pull it out by the tabs that are built into the connector ribbon.
    • Remove the small cable towards the top by pulling it straight out of its connector using tweezers or your fingers.
    • Remove both Screws on the bottom side of the motherboard
    Pergunte ao FixBot
    Comentar
  32. Canon PowerShot G16 Lens Replacement: passo 32, imagem 1 %32
    • Lift the motherboard out of the camera.
    Pergunte ao FixBot
    Comentar
  33. Canon PowerShot G16 Lens Replacement, Lens: passo 33, imagem 1 %32
    • Reorient the camera so that black lens cover is facing you with viewfinder on top.
    • Remove the four 5.3 mm screws around the lens using a Phillips #00 screwdriver.
    • Remove the 3.8 mm screw above the lens using a Phillips #00 screwdriver.
    Pergunte ao FixBot
    Comentar
  34. Canon PowerShot G16 Lens Replacement: passo 34, imagem 1 %32
    • Remove the black plastic cover surrounding the lens by gripping and lifting upwards.
    Pergunte ao FixBot
    Comentar
  35. Canon PowerShot G16 Lens Replacement: passo 35, imagem 1 %32
    • Remove the black 3.8 mm screw on the far left side using a Phillips #000 screwdriver.
    Pergunte ao FixBot
    Comentar
  36. Canon PowerShot G16 Lens Replacement: passo 36, imagem 1 %32 Canon PowerShot G16 Lens Replacement: passo 36, imagem 2 %32
    • Grip the left and right halves of the camera and wiggle them apart.
    Pergunte ao FixBot
    Comentar
  37. Canon PowerShot G16 Lens Replacement: passo 37, imagem 1 %32
    • Use caution around the black felt covered circle. This is the speaker and can easily be damaged.
    • Pick up the half of the camera that contains the lens.
    • Remove top 4 mm screw from the strap holder using a Phillips #00 screwdriver.
    • Remove the middle 3.8 mm screw next to the left speaker using a Phillips #00 screwdriver.
    Pergunte ao FixBot
    Comentar
  38. Canon PowerShot G16 Lens Replacement: passo 38, imagem 1 %32
    • Remove the cable strap bracket by lifting it away.
    Pergunte ao FixBot
    Comentar
  39. Canon PowerShot G16 Lens Replacement: passo 39, imagem 1 %32
    • Do not pull the connector upwards because doing so may harm the connector housing.
    • Be carful not to pinch the cable while pulling it out.
    • Disconnect the cable in the top left by pulling it straight out of its connector.
    Pergunte ao FixBot
    Comentar
  40. Canon PowerShot G16 Lens Replacement: passo 40, imagem 1 %32 Canon PowerShot G16 Lens Replacement: passo 40, imagem 2 %32
    • Lift the metal frame away from the lens.
    • After you remove the metal frame, the lens will be by itself.
    Pergunte ao FixBot
    Comentar
Conclusão
To reassemble your Canon PowerShot G16, follow these instructions in reverse order.
14 outras pessoas executaram este guia.
Tyler Koski
Membro desde: 01/11/16
333 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 70-6, Forte Winter 2016 Membro de Cal Poly, Team 70-6, Forte Winter 2016
CPSU-FORTE-W16S70G6
4 Membros
Autoria de 7 guias
9Comentários do guia
A well understood and skillfully documented and photographed guide. Not for the faint hearted, but that's not the author's fault!
cambrs00 - Responder Compartilhar
I would like to thank you for the guide. I used this guide yesterday to change the lenses of a G15. It has some differences, but your guide helped me a lot. I'm not a technician and I almost gave up on the way, but in the end everything worked out. Thanks!
Daniel Simões - Responder Compartilhar
You haven’t disassembled the lens yet or exposed the sensor which may have dust on it and be in need of cleaning or even replacement. How is that done, wise guy?
Benjamin Netanyahu - Responder Compartilhar
Anybody knows a good and reliable seller where i can buy the lens replacement part for the canon g16? Thanks!
Darío Fernández - Responder Compartilhar
To be clear, can this procedure be used to replace a lens that has got stuck due to a drop? And a source(s) for the replacement part would be great.
Greg Scott - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 17
Últimos 30 dias: 106
Ao todo: 12,087
