Ir para o conteúdo principal
Canon PowerShot G11 Rear Dial Replacement
O que você precisa
    1. Canon PowerShot G11 Rear Dial Replacement, Rear Cover: passo 1, imagem 1 %32
      • Remove the three screws on the bottom of the camera using the 00 sized phillips head screw driver.
      Pergunte ao FixBot
      Comentar
    2. Canon PowerShot G11 Rear Dial Replacement: passo 2, imagem 1 %32
      • Remove the four screws on the left side of the camera.
      Pergunte ao FixBot
      Comentar
    3. Canon PowerShot G11 Rear Dial Replacement: passo 3, imagem 1 %32
      • Remove the screw on the right side of the camera.
      Pergunte ao FixBot
      Comentar
    4. Canon PowerShot G11 Rear Dial Replacement: passo 4, imagem 1 %32
      • Open up the HDMI port on the right side of the camera. Then remove the screw in the HDMI port.
      Pergunte ao FixBot
      Comentar
    5. Canon PowerShot G11 Rear Dial Replacement: passo 5, imagem 1 %32
      • Remove the screw to the right of the view finder on the rear of the camera.
      Pergunte ao FixBot
      Comentar
    6. Canon PowerShot G11 Rear Dial Replacement: passo 6, imagem 1 %32
      • Use the spudger to crack open the case.
      Pergunte ao FixBot
      Comentar
    7. Canon PowerShot G11 Rear Dial Replacement: passo 7, imagem 1 %32
      Ferramenta utilizada neste passo:
      • The rear case is still attached to the camera with a ribbon cable. The socket has a flip up lid that must be flipped up before the cable can be removed. Use the tweezers to flip the cable attachment up.
      Pergunte ao FixBot
      Comentar
    8. Canon PowerShot G11 Rear Dial Replacement: passo 8, imagem 1 %32
      • The rear cover is now unattached from the camera.
      Pergunte ao FixBot
      Comentar
    1. Canon PowerShot G11 Rear Dial Replacement, Rear Dial: passo 9, imagem 1 %32
      • Remove the plastic covering of the left side of the rear case interior.
      Pergunte ao FixBot
      Comentar
    2. Canon PowerShot G11 Rear Dial Replacement: passo 10, imagem 1 %32
      • Remove the four screws that are now accessible with the removal of the plastic covering them.
      Pergunte ao FixBot
      Comentar
    3. Canon PowerShot G11 Rear Dial Replacement: passo 11, imagem 1 %32 Canon PowerShot G11 Rear Dial Replacement: passo 11, imagem 2 %32
      • After the screws are removed, pull the metal bracket out of the camera.
      Pergunte ao FixBot
      Comentar
    4. Canon PowerShot G11 Rear Dial Replacement: passo 12, imagem 1 %32
      • Push the dial out from the other side of the cover.
      Pergunte ao FixBot
      Comentar
    5. Canon PowerShot G11 Rear Dial Replacement: passo 13, imagem 1 %32
      • Remove the dial from the case completely.
      Pergunte ao FixBot
      Comentar
Conclusão
3 outras pessoas executaram este guia.
Dustin Brinegar
Membro desde: 01/21/15
715 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team 5-6, Brown Winter 2015 Membro de USF Tampa, Team 5-6, Brown Winter 2015
USFT-BROWN-W15S5G6
3 Membros
Autoria de 26 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 35
Ao todo: 2,746
