Introdução
The device should be turned off and the battery and memory card removed before you start the guide.
O que você precisa
Remove the three screws on the bottom of the camera using the 00 sized phillips head screw driver.
Push the button on the bottom right of the camera and then remove the plastic surrounding the lens.
3 outras pessoas executaram este guia.
