Ir para o conteúdo principal
Canon PowerShot ELPH 310 HS Shutter Button Replacement
O que você precisa
    1. Canon PowerShot ELPH 310 HS Shutter Button Replacement, External Panels: passo 1, imagem 1 %32
      • Use the Phillips #000 screwdriver from the iFixit tool kit to unscrew the two image stabilizer panel’s 2 mm Phillips head screws.
      • Using your hands, remove the image stabilizer panel.
      Pergunte ao FixBot
      Comentar
    2. Canon PowerShot ELPH 310 HS Shutter Button Replacement: passo 2, imagem 1 %32 Canon PowerShot ELPH 310 HS Shutter Button Replacement: passo 2, imagem 2 %32
      • Unscrew the two 4 mm Phillips head screws from the bottom side of the camera.
      Pergunte ao FixBot
      Comentar
    3. Canon PowerShot ELPH 310 HS Shutter Button Replacement: passo 3, imagem 1 %32 Canon PowerShot ELPH 310 HS Shutter Button Replacement: passo 3, imagem 2 %32
      • Using your hand, open the battery portal located on the bottom left of the camera. The screw is in the bottom left of the battery portal.
      • Unscrew the hidden 4mm Phillips head screw inside the battery portal.
      Pergunte ao FixBot
      Comentar
    4. Canon PowerShot ELPH 310 HS Shutter Button Replacement: passo 4, imagem 1 %32 Canon PowerShot ELPH 310 HS Shutter Button Replacement: passo 4, imagem 2 %32
      • Remove the HDMI side panel with your hands.
      • Unscrew the four 4 mm Phillips head screws from the inside of the camera.
      Pergunte ao FixBot
      Comentar
    5. Canon PowerShot ELPH 310 HS Shutter Button Replacement: passo 5, imagem 1 %32
      • The back side of the camera should pop off or be removed by hand.
      Pergunte ao FixBot
      Comentar
    6. Canon PowerShot ELPH 310 HS Shutter Button Replacement: passo 6, imagem 1 %32 Canon PowerShot ELPH 310 HS Shutter Button Replacement: passo 6, imagem 2 %32
      • Unscrew the one 3 mm Phillips head screw on the top of the camera.
      Pergunte ao FixBot
      Comentar
    7. Canon PowerShot ELPH 310 HS Shutter Button Replacement: passo 7, imagem 1 %32
      • Manually remove the front panel from the camera.
      Pergunte ao FixBot
      Comentar
    1. Canon PowerShot ELPH 310 HS Shutter Button Replacement, Shutter Button: passo 8, imagem 1 %32
      • Using your hand, lift and remove the shutter button deck from the top of camera.
      • The front clasp is fragile.
      Pergunte ao FixBot
      Comentar
    2. Canon PowerShot ELPH 310 HS Shutter Button Replacement: passo 9, imagem 1 %32
      • Unclip the cables from the front of the motherboard, using your hands.
      Pergunte ao FixBot
      Comentar
Conclusão
Brandon
Membro desde: 09/24/15
101 Reputação
Autoria de 1 guia
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 23
Ao todo: 837
