Ir para o conteúdo principal
Canon PowerShot ELPH 150 IS Card/Battery Door Replacement
  1. Canon PowerShot ELPH 150 IS Card/Battery Door Replacement, Card/Battery Door: passo 1, imagem 1 %32 Canon PowerShot ELPH 150 IS Card/Battery Door Replacement, Card/Battery Door: passo 1, imagem 2 %32
    • Safety First: Power down your camera by locating the ON/Off button on the top of the camera and holding it down until the screen and all lights on the camera go dark.
  2. Canon PowerShot ELPH 150 IS Card/Battery Door Replacement: passo 2, imagem 1 %32
    • Locate the CARD/BATT. OPEN door on the bottom right of the camera.
  3. Canon PowerShot ELPH 150 IS Card/Battery Door Replacement: passo 3, imagem 1 %32
  4. Canon PowerShot ELPH 150 IS Card/Battery Door Replacement: passo 4, imagem 1 %32 Canon PowerShot ELPH 150 IS Card/Battery Door Replacement: passo 4, imagem 2 %32
    • With the backplate removed, turn the camera so that the CARD/BATT. OPEN door is face up and to the right. Press down on the door as you slide it to the right. You should hear a click which indicates that the door is unlocked and will freely open.
  5. Canon PowerShot ELPH 150 IS Card/Battery Door Replacement: passo 5, imagem 1 %32 Canon PowerShot ELPH 150 IS Card/Battery Door Replacement: passo 5, imagem 2 %32 Canon PowerShot ELPH 150 IS Card/Battery Door Replacement: passo 5, imagem 3 %32
    • With the CARD/BATT. OPEN door open, and the backplate off, gently pull the door from a 90 degree angle back towards you. Once you hear a pop ( a sign that one side pin has released), you can slide the door away from you to release the pin on the other side as well. Remove door.
Conclusão
Morgan Forester
Membro desde: 03/21/17
284 Reputação
Autoria de 2 guias
Equipe
Um comentário
Do you know where I can find the sensor pin for the battery door? My Elph 150 won’t turn on and I was thinking that maybe the culprit. I tried new batteries to no avail, also no power when plugged in via usb. Otherwise any ideas what could have caused it, because the camera is in mint condition.
Kimo - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 8
Duração total: 415
