Ir para o conteúdo principal
Canon PowerShot A620 Camera Housing Replacement
O que você precisa
    1. Canon PowerShot A620 Camera Housing Replacement, Open Battery Door: passo 1, imagem 1 %32 Canon PowerShot A620 Camera Housing Replacement, Open Battery Door: passo 1, imagem 2 %32 Canon PowerShot A620 Camera Housing Replacement, Open Battery Door: passo 1, imagem 3 %32
      • Slide the tab on the battery door while pushing the battery door away from you. The battery door should pop open.
      Pergunte ao FixBot
      Comentar
    2. Canon PowerShot A620 Camera Housing Replacement, Insert Batteries: passo 2, imagem 1 %32 Canon PowerShot A620 Camera Housing Replacement, Insert Batteries: passo 2, imagem 2 %32
      • Insert AA batteries according to the diagram printed on the camera.
      • Close the battery door.
      Pergunte ao FixBot
      Comentar
    1. Canon PowerShot A620 Camera Housing Replacement, Side Panel: passo 3, imagem 1 %32 Canon PowerShot A620 Camera Housing Replacement, Side Panel: passo 3, imagem 2 %32 Canon PowerShot A620 Camera Housing Replacement, Side Panel: passo 3, imagem 3 %32
      • Unscrew the three Phillips #00 1.6x3mm screws on the side.
      • Lift loose panel from the case.
      • Unscrew the two Phillips #00 1.6x3mm screws that were previously hidden beneath the panel.
      Pergunte ao FixBot
      Comentar
    2. Canon PowerShot A620 Camera Housing Replacement, Bottom Panel: passo 4, imagem 1 %32
      • Unscrew the two Phillips #00 1.6x3mm screws on the bottom panel.
      Pergunte ao FixBot
      Comentar
    3. Canon PowerShot A620 Camera Housing Replacement, Battery Compartment: passo 5, imagem 1 %32
      • Open the battery door.
      • Unscrew the four Phillips #00 1.6x3mm screws in the battery compartment.
      Pergunte ao FixBot
      Comentar
    4. Canon PowerShot A620 Camera Housing Replacement, Terminal Cover: passo 6, imagem 1 %32 Canon PowerShot A620 Camera Housing Replacement, Terminal Cover: passo 6, imagem 2 %32
      • Lift the terminal cover on the side of the camera.
      • Unscrew the three Phillips #00 1.6x3mm screws beneath the terminal cover.
      Pergunte ao FixBot
      Comentar
    5. Canon PowerShot A620 Camera Housing Replacement, Top Panel: passo 7, imagem 1 %32
      • Gently pull the top panel to separate it from the case.
      • Although the top panel will now be free from the rest of the case, it will still be attached to the camera by a ribbon cable.
      Pergunte ao FixBot
      Comentar
    6. Canon PowerShot A620 Camera Housing Replacement, Front Panel: passo 8, imagem 1 %32 Canon PowerShot A620 Camera Housing Replacement, Front Panel: passo 8, imagem 2 %32
      • Gently pull the front panel to separate it from the camera.
      • The battery terminals are easy to access from this step.
      Pergunte ao FixBot
      Comentar
    7. Canon PowerShot A620 Camera Housing Replacement, Terminal Cover: passo 9, imagem 1 %32 Canon PowerShot A620 Camera Housing Replacement, Terminal Cover: passo 9, imagem 2 %32
      • Gently pull the terminal cover to separate it from the camera.
      Pergunte ao FixBot
      Comentar
    8. Canon PowerShot A620 Camera Housing Replacement, Memory Card Cover: passo 10, imagem 1 %32 Canon PowerShot A620 Camera Housing Replacement, Memory Card Cover: passo 10, imagem 2 %32
      • Slide the memory card cover down.
      • Unscrew the Phillips #00 1.6x3mm screw beneath the memory card cover.
      Pergunte ao FixBot
      Comentar
    9. Canon PowerShot A620 Camera Housing Replacement, Back Panel: passo 11, imagem 1 %32 Canon PowerShot A620 Camera Housing Replacement, Back Panel: passo 11, imagem 2 %32
      • Gently pull the back panel to separate it from the camera.
      Pergunte ao FixBot
      Comentar
Conclusão
Jaime Abraham
Membro desde: 09/08/14
350 Reputação
Autoria de 3 guias
Equipe
CSU Fullerton, Team 1-1, Bruce Fall 2014 Membro de CSU Fullerton, Team 1-1, Bruce Fall 2014
CSUF-BRUCE-F14S1G1
3 Membros
Autoria de 15 guias
1Comentário do guia
Ottima spiegazione: é tutto facile quando la spiegazione é semplice ed univoca. Ma redigere istruzioni semplici é un'arte che non tutti possiedono.
Paolo Ravera - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 19
Ao todo: 2,375
