Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
*See battery replacement guide for help opening the hatch.
The memory card slot is shown here in the red rectangle.
To eject your memory card, simply press it into the camera gently, and it will spring out.
After it has been released from the camera, just pull it out.
To replace the memory card, make sure it is oriented with the label facing towards the front of the camera, with the contacts going in first, facing the back of the camera.
Push the card into the slot gently until you hear a 'click'. It will then be locked into place in the camera.
4 outras pessoas executaram este guia.
