Ir para o conteúdo principal
Canon PowerShot A590 IS Batteries Replacement
O que você precisa
  1. Canon PowerShot A590 IS Batteries Replacement, Batteries: passo 1, imagem 1 %32 Canon PowerShot A590 IS Batteries Replacement, Batteries: passo 1, imagem 2 %32
    • The battery hatch is on the bottom of the camera.
    • CAUTION: Locate the switch to open the hatch and push gently toward the front of the camera. Too much force can break the hatch.
    • While the switch is pushed forward, pull the cover away from the camera.
  2. Canon PowerShot A590 IS Batteries Replacement: passo 2, imagem 1 %32
    • This camera requires AA batteries.
    • To remove batteries, simply allow them to fall out of the camera.
    • Use a fingernail to lift the clock battery out of the camera.
  3. Canon PowerShot A590 IS Batteries Replacement: passo 3, imagem 1 %32
    • When replacing the AA batteries, verify they are oriented correctly by following the (+) and (-) signs on the camera.
Conclusão
Zach
Membro desde: 10/11/10
284 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 9-19, Regan Fall 2010 Membro de Cal Poly, Team 9-19, Regan Fall 2010
CPSU-REGAN-F10S9G19
Membros da 4
Autoria de 14 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 24
Duração total: 7,878
