Ir para o conteúdo principal
Canon PowerShot A550 LCD Screen Replacement
O que você precisa
  1. Canon PowerShot A550 LCD Screen Replacement, Front and Back Covers: passo 1, imagem 1 %32 Canon PowerShot A550 LCD Screen Replacement, Front and Back Covers: passo 1, imagem 2 %32 Canon PowerShot A550 LCD Screen Replacement, Front and Back Covers: passo 1, imagem 3 %32
    • Unscrew a total of 6 4.45 mm phillips head screws using a #00 phillips head screwdriver.
    • There are 2 screws on the left side (when looking at the front of the camera).
    • There are 3 screws on the bottom
    • There is 1 screw on the right side
    Pergunte ao FixBot
    Comentar
  2. Canon PowerShot A550 LCD Screen Replacement: passo 2, imagem 1 %32
    • Turn to the bottom of the camera.
    • Open the memory card cover by sliding the "CARD/BATT." button up, and then pulling the cover to the left.
    Pergunte ao FixBot
    Comentar
  3. Canon PowerShot A550 LCD Screen Replacement: passo 3, imagem 1 %32
    • This is what the SD card/battery compartment looks like when opened.
    • Remove one 4.45mm phillips head screw from the SD card/battery compartment using a #00 phillips head screwdriver.
    Pergunte ao FixBot
    Comentar
  4. Canon PowerShot A550 LCD Screen Replacement: passo 4, imagem 1 %32 Canon PowerShot A550 LCD Screen Replacement: passo 4, imagem 2 %32
    • Gently remove the front cover away from the camera body.
    • Tip: Start by loosening the teeth on the left side of the camera next to the battery compartment.
    Pergunte ao FixBot
    Comentar
  5. Canon PowerShot A550 LCD Screen Replacement: passo 5, imagem 1 %32
    • The camera should look like this once the front cover is removed.
    Pergunte ao FixBot
    Comentar
  6. Canon PowerShot A550 LCD Screen Replacement: passo 6, imagem 1 %32 Canon PowerShot A550 LCD Screen Replacement: passo 6, imagem 2 %32 Canon PowerShot A550 LCD Screen Replacement: passo 6, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Start from the battery compartment and remove the back cover.
    • Caution: Do not tug on the back cover after it is removed. This could tear the ribbon attaching the back cover to the camera body.
    • Remove the connecting ribbon from the body of the camera using a pair of tweezers.
    Pergunte ao FixBot
    Comentar
  7. Canon PowerShot A550 LCD Screen Replacement: passo 7, imagem 1 %32
    • Once the ribbon connecting the back cover is removed, the back of the camera body should look like this.
    Pergunte ao FixBot
    Comentar
  8. Canon PowerShot A550 LCD Screen Replacement, LCD Screen: passo 8, imagem 1 %32
    • Use a #00 phillips head screwdriver to remove 2 3.34mm phillips screws holding the LCD screen in place.
    Pergunte ao FixBot
    Comentar
  9. Canon PowerShot A550 LCD Screen Replacement: passo 9, imagem 1 %32 Canon PowerShot A550 LCD Screen Replacement: passo 9, imagem 2 %32
    • Use an iPod Opening Tool to lift the brown portion of the connector to unlock it.
    • Slide the data cable out of the connector.
    • Caution: Do not force the data cable out of the connector. It may rip!
    Pergunte ao FixBot
    Comentar
  10. Canon PowerShot A550 LCD Screen Replacement: passo 10, imagem 1 %32
    • The LCD screen can now be be removed to be fixed/replaced.
    Pergunte ao FixBot
    Comentar
Conclusão
3 outras pessoas executaram este guia.
Equipe
Cal Poly, Team 8-6, Regan Spring 2011 Membro de Cal Poly, Team 8-6, Regan Spring 2011
CPSU-REGAN-S11S8G6
4 Membros
Autoria de 22 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 45
Ao todo: 4,191
