Ir para o conteúdo principal
Canon PowerShot A540 Function Key Motherboard Replacement
O que você precisa
  1. Canon PowerShot A540 Function Key Motherboard Replacement, Back Cover: passo 1, imagem 1 %32 Canon PowerShot A540 Function Key Motherboard Replacement, Back Cover: passo 1, imagem 2 %32
    • Turn off the camera.
    • Turn the camera upside-down and press the tab to release the battery cover. Remove the batteries.
    Pergunte ao FixBot
    Comentar
  2. Canon PowerShot A540 Function Key Motherboard Replacement: passo 2, imagem 1 %32
    • Turn the camera upside down to view the "Card/Batt. Open" Cover.
    • Use a Phillips head #000 screwdriver to remove the three (3) 4.0 mm screws.
    Pergunte ao FixBot
    Comentar
  3. Canon PowerShot A540 Function Key Motherboard Replacement: passo 3, imagem 1 %32
    • Open "Card/Batt. Open" Cover.
    • Remove the one (1) 5.0 mm screw with the Phillips head #000 screwdriver.
    Pergunte ao FixBot
    Comentar
  4. Canon PowerShot A540 Function Key Motherboard Replacement: passo 4, imagem 1 %32
    • Turn the camera to the right side of the LCD screen.
    • Remove the three (3) 4.0 mm screws with the Phillips head #000 screwdriver.
    Pergunte ao FixBot
    Comentar
  5. Canon PowerShot A540 Function Key Motherboard Replacement: passo 5, imagem 1 %32 Canon PowerShot A540 Function Key Motherboard Replacement: passo 5, imagem 2 %32 Canon PowerShot A540 Function Key Motherboard Replacement: passo 5, imagem 3 %32
    • Gently remove the back cover.
    • Start at the bottom at the corner of the "Card/Batt. Open" Cover.
    • Then move onto the other edges and the top.
    • It may be tight at the top!
    Pergunte ao FixBot
    Comentar
  6. Canon PowerShot A540 Function Key Motherboard Replacement, Function Key Motherboard: passo 6, imagem 1 %32 Canon PowerShot A540 Function Key Motherboard Replacement, Function Key Motherboard: passo 6, imagem 2 %32
    • Turn the camera to view the back.
    • Remove the one (1) 3.0 mm screw on the top right corner of the screen.
    • There is a small metal bar that rests on this frame. Keep it with the screws that have been removed from the camera.
    Pergunte ao FixBot
    Comentar
  7. Canon PowerShot A540 Function Key Motherboard Replacement: passo 7, imagem 1 %32 Canon PowerShot A540 Function Key Motherboard Replacement: passo 7, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Lift the LCD Screen off of the back to view the attached ribbon cables.
    • Use tweezers to flip the black bar up.
    Pergunte ao FixBot
    Comentar
  8. Canon PowerShot A540 Function Key Motherboard Replacement: passo 8, imagem 1 %32 Canon PowerShot A540 Function Key Motherboard Replacement: passo 8, imagem 2 %32 Canon PowerShot A540 Function Key Motherboard Replacement: passo 8, imagem 3 %32
    • Gently pull the big ribbon out.
    • Gently pull the small ribbon out.
    • The small ribbon does not have a bar like the big ribbon.
    Pergunte ao FixBot
    Comentar
  9. Canon PowerShot A540 Function Key Motherboard Replacement: passo 9, imagem 1 %32 Canon PowerShot A540 Function Key Motherboard Replacement: passo 9, imagem 2 %32
    • Remove the two (2) 3.0 mm screws with the Phillips head #000 screwdriver.
    Pergunte ao FixBot
    Comentar
  10. Canon PowerShot A540 Function Key Motherboard Replacement: passo 10, imagem 1 %32 Canon PowerShot A540 Function Key Motherboard Replacement: passo 10, imagem 2 %32
    • Remove the orange ribbon from the clamp by using a Spudger to push the bar up.
    Pergunte ao FixBot
    Comentar
  11. Canon PowerShot A540 Function Key Motherboard Replacement: passo 11, imagem 1 %32
    • Remove the Function Key Motherboard and replace.
    • There is another metal bar that comes off of the SD Card reader when screws are removed.
    Pergunte ao FixBot
    Comentar
Conclusão
Cooper Hale
Membro desde: 03/22/15
598 Reputação
Autoria de 3 guias
Equipe
Baylor, Team 7-12, Williams Spring 2015 Membro de Baylor, Team 7-12, Williams Spring 2015
BU-WILLIAMS-S15S7G12
3 Membros
Autoria de 20 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 31
Ao todo: 1,252
