Ir para o conteúdo principal
Canon PowerShot A540 Clock Battery Replacement
O que você precisa
    1. Canon PowerShot A540 Clock Battery Replacement, Clock Battery: passo 1, imagem 1 %32
      • Turn the camera upside down.
      • Press the tab to release the battery cover.
      Pergunte ao FixBot
      Comentar
    2. Canon PowerShot A540 Clock Battery Replacement: passo 2, imagem 1 %32
      Ferramenta utilizada neste passo:
      • Remove the internal Battery from the slot right above where the AA batteries fit.
      • This can be done with your fingers (as pictured) or with tweezers.
      Pergunte ao FixBot
      Comentar
    3. Canon PowerShot A540 Clock Battery Replacement: passo 3, imagem 1 %32
      • Replace the internal battery.
      Pergunte ao FixBot
      Comentar
Conclusão
9 outras pessoas executaram este guia.
Cooper Hale
Membro desde: 03/22/15
598 Reputação
Autoria de 3 guias
Equipe
Baylor, Team 7-12, Williams Spring 2015 Membro de Baylor, Team 7-12, Williams Spring 2015
BU-WILLIAMS-S15S7G12
3 Membros
Autoria de 20 guias
6Comentários do guia
Very useful information, thank you.
Bob C - Responder Compartilhar
Also, nice fingernails!
Charlie Shaw - Responder Compartilhar
I am a retired professional phographer with 60 years of experience and own several cameras including FX. Yet I didn’t remember how to change the clock battery on this little gem which I occasionally still use. Thanks for the refresher!
MASSEY JONES - Responder Compartilhar
There is nothing in the manual concerning this battery. When I was told it needed replacement I was lucky to find this clear explanation to do it. It was a CR1220 battery. Thank you, Cooper Hale.
Thomas Combs - Responder Compartilhar
Hello! I did this but my camera keeps saying that the battery is empty. Anyone know what else I can try? Or is my camera just broken?
Sanne x - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 25
Últimos 30 dias: 205
Ao todo: 12,753
