Ir para o conteúdo principal
Canon PowerShot A460 Front Lens Replacement
O que você precisa
    1. Canon PowerShot A460 Front Lens Replacement, Battery: passo 1, imagem 1 %32
      • Slide the switch on the battery cover labeled "CARD/BATT. OPEN." to the right.
      • While still holding the switch, pull the cover down, allowing it to release and open.
      Pergunte ao FixBot
      Comentar
    2. Canon PowerShot A460 Front Lens Replacement: passo 2, imagem 1 %32
      • Tilt the camera slightly to allow the batteries to fall out.
      Pergunte ao FixBot
      Comentar
    3. Canon PowerShot A460 Front Lens Replacement: passo 3, imagem 1 %32
      • Press on and release the memory card to eject it.
      Pergunte ao FixBot
      Comentar
    1. Canon PowerShot A460 Front Lens Replacement, Front Casing: passo 4, imagem 1 %32
      • Unscrew the 5mm Phillips #00 screw from the bottom of the camera.
      • Make sure to keep the different size screws organized to make reassembling the camera simpler.
      Pergunte ao FixBot
      Comentar
    2. Canon PowerShot A460 Front Lens Replacement: passo 5, imagem 1 %32
      • Unscrew the three 2mm Phillips #00 screws that are located on the bottom of the camera.
      Pergunte ao FixBot
      Comentar
    3. Canon PowerShot A460 Front Lens Replacement: passo 6, imagem 1 %32
      • Remove the 4mm Phillips #00 screw that is located on the left side of the camera, if the display screen is facing you.
      Pergunte ao FixBot
      Comentar
    4. Canon PowerShot A460 Front Lens Replacement: passo 7, imagem 1 %32
      • Take out the 4mm Phillips #00 screw under the rubber flap on the right end of the camera.
      Pergunte ao FixBot
      Comentar
    5. Canon PowerShot A460 Front Lens Replacement: passo 8, imagem 1 %32 Canon PowerShot A460 Front Lens Replacement: passo 8, imagem 2 %32
      • Remove the second battery cover on the bottom of camera.
      • Take the silver battery out of the camera.
      Pergunte ao FixBot
      Comentar
    6. Canon PowerShot A460 Front Lens Replacement: passo 9, imagem 1 %32 Canon PowerShot A460 Front Lens Replacement: passo 9, imagem 2 %32 Canon PowerShot A460 Front Lens Replacement: passo 9, imagem 3 %32
      • Remove the 4mm Phillips #00 screw on the inside of the flap that hides the battery and memory card slots.
      • Remove the light grey, plastic piece.
      • Remove the plastic portion of the battery flap cover. The metal piece will remain attached.
      Pergunte ao FixBot
      Comentar
    7. Canon PowerShot A460 Front Lens Replacement: passo 10, imagem 1 %32 Canon PowerShot A460 Front Lens Replacement: passo 10, imagem 2 %32 Canon PowerShot A460 Front Lens Replacement: passo 10, imagem 3 %32
      • Slightly pull on each side of the camera. It should loosen up and come apart.
      • If it does not pull apart right away, use a little more force.
      • Do not give up!
      Pergunte ao FixBot
      Comentar
    1. Canon PowerShot A460 Front Lens Replacement, Back Casing: passo 11, imagem 1 %32
      • Remove the back case of the camera by pulling from the top.
      • Be careful when pulling off the case. There is a delicate gold ribbon connecting the bottom of the camera to the back case.
      Pergunte ao FixBot
      Comentar
    1. Canon PowerShot A460 Front Lens Replacement, LCD Screen: passo 12, imagem 1 %32
      • Remove the 4mm Phillips #00 screw from above the ribbon.
      Pergunte ao FixBot
      Comentar
    2. Canon PowerShot A460 Front Lens Replacement: passo 13, imagem 1 %32
      • Gently peel off the blue tape on the top of the LCD screen.
      Pergunte ao FixBot
      Comentar
    3. Canon PowerShot A460 Front Lens Replacement: passo 14, imagem 1 %32
      • Remove the 4mm Phillips #00 screw previously concealed by the blue tape.
      Pergunte ao FixBot
      Comentar
    4. Canon PowerShot A460 Front Lens Replacement: passo 15, imagem 1 %32
      • Gently lift the LCD screen off of the front casing by pulling up a tab on the side of the camera.
      Pergunte ao FixBot
      Comentar
    5. Canon PowerShot A460 Front Lens Replacement: passo 16, imagem 1 %32
      • Using a spudger, lift the grey tabs to allow the ribbon to slide out.
      Pergunte ao FixBot
      Comentar
    6. Canon PowerShot A460 Front Lens Replacement: passo 17, imagem 1 %32
      • Since the tabs have been lifted, the ribbon should now slide out out easily.
      • Be careful not to distort the ribbon in any way.
      Pergunte ao FixBot
      Comentar
    1. Canon PowerShot A460 Front Lens Replacement, Motherboard: passo 18, imagem 1 %32
      • Remove the 5mm Phillips #00 screw located above the small black piece on the right side of the mother board.
      Pergunte ao FixBot
      Comentar
    2. Canon PowerShot A460 Front Lens Replacement: passo 19, imagem 1 %32 Canon PowerShot A460 Front Lens Replacement: passo 19, imagem 2 %32
      • Remove the 4mm Phillips #00 screw at the bottom of the black piece.
      • Detach the black piece that the screws previously held in place.
      Pergunte ao FixBot
      Comentar
    3. Canon PowerShot A460 Front Lens Replacement: passo 20, imagem 1 %32
      • Remove the 5mm Phillips #00 screw in the middle of the motherboard.
      Pergunte ao FixBot
      Comentar
    4. Canon PowerShot A460 Front Lens Replacement: passo 21, imagem 1 %32
      • Remove the 5mm Phillips #00 screw that holds the metal piece to the bottom of the camera .
      Pergunte ao FixBot
      Comentar
    5. Canon PowerShot A460 Front Lens Replacement: passo 22, imagem 1 %32
      • Remove the 5mm Phillips #00 screw that is located on the top of camera.
      Pergunte ao FixBot
      Comentar
    6. Canon PowerShot A460 Front Lens Replacement: passo 23, imagem 1 %32
      • Remove the 2mm Phillips #00 screw that is located on the far left of the motherboard.
      • Be careful not to damage the multiple adjacent orange ribbons.
      Pergunte ao FixBot
      Comentar
    7. Canon PowerShot A460 Front Lens Replacement: passo 24, imagem 1 %32
      • Remove the 5mm Phillips #00 screw near the bottom left of the motherboard.
      Pergunte ao FixBot
      Comentar
    8. Canon PowerShot A460 Front Lens Replacement: passo 25, imagem 1 %32 Canon PowerShot A460 Front Lens Replacement: passo 25, imagem 2 %32
      • Using a spudger, unlock the locking mechanism that holds the lower orange ribbon in place.
      • Once unlocked, slide out the ribbon.
      Pergunte ao FixBot
      Comentar
    9. Canon PowerShot A460 Front Lens Replacement: passo 26, imagem 1 %32
      • Using a spudger, unlock the locking mechanism that holds the upper orange ribbon in place.
      Pergunte ao FixBot
      Comentar
    10. Canon PowerShot A460 Front Lens Replacement: passo 27, imagem 1 %32
      • All that is required is to unsolder the few remaining wires. Then, the motherboard will be ready to be replaced!
      Pergunte ao FixBot
      Comentar
    1. Canon PowerShot A460 Front Lens Replacement, Front Lens: passo 28, imagem 1 %32
      • Remove the six 2mm Phillips #00 screws that are located under the motherboard.
      Pergunte ao FixBot
      Comentar
    2. Canon PowerShot A460 Front Lens Replacement: passo 29, imagem 1 %32 Canon PowerShot A460 Front Lens Replacement: passo 29, imagem 2 %32
      • Remove the 4mm Phillips #00 screw that is located under the now disconnected top orange ribbon.
      • The lens piece can now be removed from the camera.
      Pergunte ao FixBot
      Comentar
    3. Canon PowerShot A460 Front Lens Replacement: passo 30, imagem 1 %32
      • Remove the 5mm Phillips #00 screw on the back of the lens piece.
      Pergunte ao FixBot
      Comentar
    4. Canon PowerShot A460 Front Lens Replacement: passo 31, imagem 1 %32
      • Remove the 2mm Phillips #00 screw on the bottom of the lens piece.
      Pergunte ao FixBot
      Comentar
    5. Canon PowerShot A460 Front Lens Replacement: passo 32, imagem 1 %32
      • Remove the two 2mm Phillips #00 screws on the top of the lens piece.
      Pergunte ao FixBot
      Comentar
    6. Canon PowerShot A460 Front Lens Replacement: passo 33, imagem 1 %32
      • Gently slide off the black piece surrounding the lens. The lens is now disassembled!
      Pergunte ao FixBot
      Comentar
Conclusão
4 outras pessoas executaram este guia.
Equipe
Cal Poly, Team 19-42, Regan Winter 2013 Membro de Cal Poly, Team 19-42, Regan Winter 2013
CPSU-REGAN-W13S19G42
4 Membros
Autoria de 12 guias
1Comentário do guia
please put a big warning note on the step after removing the blue tape from the lens. and the next on is where you lift something on the mother board with a spluger..something like that. well i used a screwdriver and got such a big electrical shock.... scared the crapola out of me. please make a note .... can get electrical shock....
Gaby - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 24
Últimos 30 dias: 80
Ao todo: 5,674
