Ir para o conteúdo principal
Canon PowerShot A4000 IS Flash Replacement
O que você precisa
  1. Canon PowerShot A4000 IS Flash Replacement, Removing the Screws Anchoring the Front Cover: passo 1, imagem 1 %32 Canon PowerShot A4000 IS Flash Replacement, Removing the Screws Anchoring the Front Cover: passo 1, imagem 2 %32 Canon PowerShot A4000 IS Flash Replacement, Removing the Screws Anchoring the Front Cover: passo 1, imagem 3 %32
    • Remove the battery and data card. Refer to the Battery Removal and Memory Card Removal guides.
    • Use a Philips head screwdriver (PH000) to remove the screws circled in the picture. Screw Sizes: 4 millimeters.
  2. Canon PowerShot A4000 IS Flash Replacement: passo 2, imagem 1 %32 Canon PowerShot A4000 IS Flash Replacement: passo 2, imagem 2 %32
    • Use the spudger tool to gently lever the front cover off.
  3. Canon PowerShot A4000 IS Flash Replacement, Removing the Flash: passo 3, imagem 1 %32 Canon PowerShot A4000 IS Flash Replacement, Removing the Flash: passo 3, imagem 2 %32 Canon PowerShot A4000 IS Flash Replacement, Removing the Flash: passo 3, imagem 3 %32
    • The flash is not held very securely in the camera so be careful. Make sure someone is holding on to it so it does not fall out.
    • Your flash should come out very easily if you use your spudger to lever it out carefully.
    • Once the bulb piece of the flash is clear of the camera body, simply use your fingers to lift the flash clear of the camera.
Conclusão
Ansley Gardner
Membro desde: 10/13/14
761 Reputação
Autoria de 7 guias
Equipe
Clemson, Team 1-3, Benson Fall 2014 Membro de Clemson, Team 1-3, Benson Fall 2014
CLEM-BENSON-F14S1G3
Membros da 3
Autoria de 17 guias
Um comentário
Hello! thank you for this flash replacement guide. I would like to know: can the flash be repaired or is it only replaceable? Thank you!
Jeiler AV - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 22
Duração total: 1,557
