O que você precisa
Remove the battery and data card. Refer to the Battery Removal and Memory Card Removal guides.
Use a Philips head screwdriver (PH000) to remove the screws circled in the picture. Screw Sizes: 4 millimeters.
Your flash should come out very easily if you use your spudger to lever it out carefully.
Once the bulb piece of the flash is clear of the camera body, simply use your fingers to lift the flash clear of the camera.
Quase terminado!
Conclusão
