Ir para o conteúdo principal
Canon PowerShot A3400 IS Flash Assembly Replacement
O que você precisa
    1. Canon PowerShot A3400 IS Flash Assembly Replacement, Battery: passo 1, imagem 1 %32
      • Place thumb on area right next to where it says open and slide to the right to open.
      Pergunte ao FixBot
      Comentar
    2. Canon PowerShot A3400 IS Flash Assembly Replacement: passo 2, imagem 1 %32
      • Remove the battery by pushing the orange object outwards; the battery will spring up and out.
      Pergunte ao FixBot
      Comentar
    1. Canon PowerShot A3400 IS Flash Assembly Replacement, Plastic Case: passo 3, imagem 1 %32 Canon PowerShot A3400 IS Flash Assembly Replacement, Plastic Case: passo 3, imagem 2 %32
      • Remove the two 5.00 mm screws in the bottom of the casing with a Philips #000 screwdriver
      Pergunte ao FixBot
      Comentar
    2. Canon PowerShot A3400 IS Flash Assembly Replacement: passo 4, imagem 1 %32 Canon PowerShot A3400 IS Flash Assembly Replacement: passo 4, imagem 2 %32
      • Place the camera on to the side that has the image stabilizer label.
      • Remove the 5.00 mm screws that are on this side using the screwdriver.
      Pergunte ao FixBot
      Comentar
    3. Canon PowerShot A3400 IS Flash Assembly Replacement: passo 5, imagem 1 %32
      • Place camera on to the side with the A/V Out Digital Cover facing up.
      • Remove this visible 5.00 mm screw.
      • Pull the A/V Out Digital cover back to uncover the next step.
      Pergunte ao FixBot
      Comentar
    4. Canon PowerShot A3400 IS Flash Assembly Replacement: passo 6, imagem 1 %32
      • Remove the 5.00 mm screw from behind the cover.
      Pergunte ao FixBot
      Comentar
    5. Canon PowerShot A3400 IS Flash Assembly Replacement: passo 7, imagem 1 %32
      • Make sure the battery cover is open.
      Pergunte ao FixBot
      Comentar
    6. Canon PowerShot A3400 IS Flash Assembly Replacement: passo 8, imagem 1 %32 Canon PowerShot A3400 IS Flash Assembly Replacement: passo 8, imagem 2 %32
      • Turn the camera onto the side with the A/V out Digital cover.
      • Use your finger to pull this tab to the right.
      Pergunte ao FixBot
      Comentar
    7. Canon PowerShot A3400 IS Flash Assembly Replacement: passo 9, imagem 1 %32 Canon PowerShot A3400 IS Flash Assembly Replacement: passo 9, imagem 2 %32 Canon PowerShot A3400 IS Flash Assembly Replacement: passo 9, imagem 3 %32
      • Remove the lens side by using your fingers or a spudger to pry it gently open.
      • Try to pry it loose all around that side so that it is easier to pull off.
      Pergunte ao FixBot
      Comentar
    8. Canon PowerShot A3400 IS Flash Assembly Replacement: passo 10, imagem 1 %32 Canon PowerShot A3400 IS Flash Assembly Replacement: passo 10, imagem 2 %32 Canon PowerShot A3400 IS Flash Assembly Replacement: passo 10, imagem 3 %32
      • Using your fingers, pull the screen side gently off.
      • Try to loosen it all around that side so that it is easier to try and pull it off.
      Pergunte ao FixBot
      Comentar
    1. Canon PowerShot A3400 IS Flash Assembly Replacement, Flash: passo 11, imagem 1 %32 Canon PowerShot A3400 IS Flash Assembly Replacement, Flash: passo 11, imagem 2 %32 Canon PowerShot A3400 IS Flash Assembly Replacement, Flash: passo 11, imagem 3 %32
      • Remove the three 5 mm screws
      Pergunte ao FixBot
      Comentar
    2. Canon PowerShot A3400 IS Flash Assembly Replacement: passo 12, imagem 1 %32 Canon PowerShot A3400 IS Flash Assembly Replacement: passo 12, imagem 2 %32 Canon PowerShot A3400 IS Flash Assembly Replacement: passo 12, imagem 3 %32
      • Remove the screen by pulling at the two points as shown.
      Pergunte ao FixBot
      Comentar
    3. Canon PowerShot A3400 IS Flash Assembly Replacement: passo 13, imagem 1 %32 Canon PowerShot A3400 IS Flash Assembly Replacement: passo 13, imagem 2 %32
      • Remove the metal plate with the plastic opening tool.
      Pergunte ao FixBot
      Comentar
    4. Canon PowerShot A3400 IS Flash Assembly Replacement: passo 14, imagem 1 %32 Canon PowerShot A3400 IS Flash Assembly Replacement: passo 14, imagem 2 %32
      • Remove the 5 mm screw
      Pergunte ao FixBot
      Comentar
    5. Canon PowerShot A3400 IS Flash Assembly Replacement: passo 15, imagem 1 %32 Canon PowerShot A3400 IS Flash Assembly Replacement: passo 15, imagem 2 %32 Canon PowerShot A3400 IS Flash Assembly Replacement: passo 15, imagem 3 %32
      • Gently pull the flash assembly away.
      Pergunte ao FixBot
      Comentar
Conclusão
1Comentário do guia
easy to take off but waste of putting it back together..
The Heat - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 27
Ao todo: 988
