Introdução
The lens mechanism is the allows photos to use the zoom feature. It will also cause distortions in photos if it is malfunctioning.
O que você precisa
Open the latch at the bottom corner of the device to reveal the battery and SD card housing.
There is an orange latch holding the battery in place which must be pushed back in order to free the battery.
Once the battery is removed push the SD card and this will activate a spring ejecting the card from the camera.
Remove the single philips #00 screw on the button pad which are 2.2mm long. This screw is circled in red in the guide image.
Next, remove the two 2.4mm long screws located in between the LCD screen and the touch pad. These screws will require a Phillips #00 screwdriver.
Pop the LCD display out of its frame using the plastic opening tool in order to get to the screws under the display. Use the plastic opening tool to complete this step
Lift the tabs at the end of both ribbons
Disconnect each ribbon from the circuit board
