Ir para o conteúdo principal
Canon PowerShot A2200 LCD Screen Replacement
O que você precisa
    1. Canon PowerShot A2200 LCD Screen Replacement, Back Cover: passo 1, imagem 1 %32
      • First, remove the batteries and memory card.
      • Remove the 5.0 mm black screw with a Phillips #00 screwdriver.
      • Remove the 5.0 mm silver screw with a Phillips #00 screwdriver.
      Pergunte ao FixBot
      Comentar
    2. Canon PowerShot A2200 LCD Screen Replacement: passo 2, imagem 1 %32
      • Remove the 5.0 mm black screw on the right with a Phillips #00 screwdriver.
      Pergunte ao FixBot
      Comentar
    3. Canon PowerShot A2200 LCD Screen Replacement: passo 3, imagem 1 %32
      • Remove the 5.0 mm screw on the left with a Phillips #00 screwdriver.
      Pergunte ao FixBot
      Comentar
    4. Canon PowerShot A2200 LCD Screen Replacement: passo 4, imagem 1 %32 Canon PowerShot A2200 LCD Screen Replacement: passo 4, imagem 2 %32 Canon PowerShot A2200 LCD Screen Replacement: passo 4, imagem 3 %32
      • Begin taking off the back cover with a plastic opening tool.
      • Begin by wedging the plastic opening tool behind the bottom left corner of the LCD screen as shown.
      • Slide the plastic opening tool to the right, along the mating edge, to pry off the back cover.
      • Continue taking off the back cover along the left side of the camera as seen in the third picture.
      Pergunte ao FixBot
      Comentar
    5. Canon PowerShot A2200 LCD Screen Replacement: passo 5, imagem 1 %32 Canon PowerShot A2200 LCD Screen Replacement: passo 5, imagem 2 %32 Canon PowerShot A2200 LCD Screen Replacement: passo 5, imagem 3 %32
      • Use the plastic opening tool to separate the top section of the back cover from the frame.
      • Once there is enough separation between the back cover and the frame, remove the back cover for replacement.
      Pergunte ao FixBot
      Comentar
    1. Canon PowerShot A2200 LCD Screen Replacement, Button Assembly: passo 6, imagem 1 %32 Canon PowerShot A2200 LCD Screen Replacement, Button Assembly: passo 6, imagem 2 %32
      • Remove the internal 4.4mm screw with a Phillips 00 screwdriver.
      • Make sure you're removing the screw circled in red, not the screw crossed out in orange.
      Pergunte ao FixBot
      Comentar
    2. Canon PowerShot A2200 LCD Screen Replacement: passo 7, imagem 1 %32
      • Gently lift of the buttons for replacement. They should come off without excessive force.
      • If the buttons do not lift off easily, you may have unscrewed the wrong screw. Revert to previous step.
      Pergunte ao FixBot
      Comentar
    1. Canon PowerShot A2200 LCD Screen Replacement, LCD Screen: passo 8, imagem 1 %32
      • Lift up the electrical ribbon shown to access the next screw.
      • Remove the 3.9 mm screw with a Phillips #00 screwdriver.
      Pergunte ao FixBot
      Comentar
    2. Canon PowerShot A2200 LCD Screen Replacement: passo 9, imagem 1 %32
      Pergunte ao FixBot
      Comentar
    3. Canon PowerShot A2200 LCD Screen Replacement: passo 10, imagem 1 %32
      • Remove the two 3.9 mm screws shown with a Phillips #00 screwdriver.
      Pergunte ao FixBot
      Comentar
    4. Canon PowerShot A2200 LCD Screen Replacement: passo 11, imagem 1 %32 Canon PowerShot A2200 LCD Screen Replacement: passo 11, imagem 2 %32
      • There is an electrical flap that holds the LCD ribbon down. Note the flap in is closed position.
      • Lift up the flap with a plastic opening tool.
      Pergunte ao FixBot
      Comentar
    5. Canon PowerShot A2200 LCD Screen Replacement: passo 12, imagem 1 %32
      • Holding the outer frame of the LCD screen, gently lift the LCD screen for replacement.
      Pergunte ao FixBot
      Comentar
    6. Canon PowerShot A2200 LCD Screen Replacement: passo 13, imagem 1 %32 Canon PowerShot A2200 LCD Screen Replacement: passo 13, imagem 2 %32 Canon PowerShot A2200 LCD Screen Replacement: passo 13, imagem 3 %32
      • This step is only for replacement. If you are not replacing the LCD screen, skip this step.
      • Locate ribbon flap, enclosed in red. (picture 1)
      • Using a plastic opening tool, lift up the ribbon flap to allow insertion of the LCD ribbon. (picture 2)
      • Place the LCD screen on the camera and align the ribbon underneath the open ribbon flap. Close the ribbon flap onto the ribbon. (picture 3)
      Pergunte ao FixBot
      Comentar
Conclusão
To reassemble your device, follow these instructions in reverse order, starting with the last guide step.
Uma outra pessoa concluiu este guia.
Benjamin Gee
Membro desde: 03/31/15
983 Reputação
Autoria de 5 guias
Equipe
Baylor, Team 4-5, Williams Spring 2015 Membro de Baylor, Team 4-5, Williams Spring 2015
BU-WILLIAMS-S15S4G5
4 Membros
Autoria de 13 guias
2Comentários do guia
Step 11, “lift up the flap” did the trick - thanks !!
Mine got wet with seawater, I cleaned the electronics wih alcohol and it works again.
Chris W - Responder Compartilhar
My problem is after taking a photo and seeing the preview instead of going back to “live” display for the next photo the screen goes black but the camera settings still show.  Would changing the screen solve this problem?
Ken Short - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 7
Últimos 7 dias: 26
Últimos 30 dias: 79
Ao todo: 2,372
