Ir para o conteúdo principal
Canon Pixma MP480 Buttons Replacement
O que você precisa
    1. Canon Pixma MP480 Buttons Replacement, Rear and Side Panel: passo 1, imagem 1 %32 Canon Pixma MP480 Buttons Replacement, Rear and Side Panel: passo 1, imagem 2 %32
      • Remove the two 7.9 mm screws using a Phillips #1 screwdriver.
      Pergunte ao FixBot
      Comentar
    2. Canon Pixma MP480 Buttons Replacement: passo 2, imagem 1 %32
      • Lift up the back cover to remove it.
      • You may need to lift firmly as it requires quite a bit of force.
      Pergunte ao FixBot
      Comentar
    3. Canon Pixma MP480 Buttons Replacement: passo 3, imagem 1 %32
      • Open the front tray.
      Pergunte ao FixBot
      Comentar
    4. Canon Pixma MP480 Buttons Replacement: passo 4, imagem 1 %32 Canon Pixma MP480 Buttons Replacement: passo 4, imagem 2 %32
      • Open the scanner compartment.
      • Make sure the blue lever locks into place to keep the compartment open.
      Pergunte ao FixBot
      Comentar
    5. Canon Pixma MP480 Buttons Replacement: passo 5, imagem 1 %32 Canon Pixma MP480 Buttons Replacement: passo 5, imagem 2 %32
      • Remove the blue lever from its slot by pushing it back and twisting clockwise.
      • Close the scanner compartment and cover.
      Pergunte ao FixBot
      Comentar
    6. Canon Pixma MP480 Buttons Replacement: passo 6, imagem 1 %32 Canon Pixma MP480 Buttons Replacement: passo 6, imagem 2 %32
      • Pry open the side cover with the plastic opening tool.
      Pergunte ao FixBot
      Comentar
    7. Canon Pixma MP480 Buttons Replacement: passo 7, imagem 1 %32 Canon Pixma MP480 Buttons Replacement: passo 7, imagem 2 %32
      • Flip the printer over so that the bottom of the printer is facing you.
      • Use the plastic opening tool to remove the corner of the side panel from the plastic pin.
      Pergunte ao FixBot
      Comentar
    8. Canon Pixma MP480 Buttons Replacement: passo 8, imagem 1 %32 Canon Pixma MP480 Buttons Replacement: passo 8, imagem 2 %32
      • Use the plastic opening tool to loosen the side panel from the bottom of the printer.
      Pergunte ao FixBot
      Comentar
    1. Canon Pixma MP480 Buttons Replacement, LCD: passo 9, imagem 1 %32 Canon Pixma MP480 Buttons Replacement, LCD: passo 9, imagem 2 %32
      • Using the plastic opening tool, pry off the top cover of the LCD assembly.
      • Pry around the front and side edges for the easiest removal.
      Pergunte ao FixBot
      Comentar
    2. Canon Pixma MP480 Buttons Replacement: passo 10, imagem 1 %32
      • After removing the top cover of the LCD assembly, remove the LCD using the plastic opening tool.
      Pergunte ao FixBot
      Comentar
    3. Canon Pixma MP480 Buttons Replacement: passo 11, imagem 1 %32
      • Gently pull the ribbon cable to remove the LCD completely.
      Pergunte ao FixBot
      Comentar
    1. Canon Pixma MP480 Buttons Replacement, Buttons: passo 12, imagem 1 %32
      • Locate the buttons on the top of the printer.
      Pergunte ao FixBot
      Comentar
    2. Canon Pixma MP480 Buttons Replacement: passo 13, imagem 1 %32
      • Using the plastic opening tool, gently pry under the button cover to remove it from its fixture.
      Pergunte ao FixBot
      Comentar
    3. Canon Pixma MP480 Buttons Replacement: passo 14, imagem 1 %32 Canon Pixma MP480 Buttons Replacement: passo 14, imagem 2 %32
      • Remove the five 7.7 mm screws using a Phillips #1 screwdriver.
      Pergunte ao FixBot
      Comentar
    4. Canon Pixma MP480 Buttons Replacement: passo 15, imagem 1 %32 Canon Pixma MP480 Buttons Replacement: passo 15, imagem 2 %32
      • Using the plastic opening tool, gently pry around the cover behind the LCD screen to remove it from its fixture.
      Pergunte ao FixBot
      Comentar
    5. Canon Pixma MP480 Buttons Replacement: passo 16, imagem 1 %32 Canon Pixma MP480 Buttons Replacement: passo 16, imagem 2 %32
      • Remove the two 7.8 mm screws using a Phillips #1 screwdriver.
      Pergunte ao FixBot
      Comentar
    6. Canon Pixma MP480 Buttons Replacement: passo 17, imagem 1 %32
      • Gently pull the LCD screen up to remove it from its fixture.
      Pergunte ao FixBot
      Comentar
    7. Canon Pixma MP480 Buttons Replacement: passo 18, imagem 1 %32
      • Use the plastic opening tool to pry off the plastic button assembly.
      Pergunte ao FixBot
      Comentar
    8. Canon Pixma MP480 Buttons Replacement: passo 19, imagem 1 %32
      • Gently pull the plastic button assembly up to remove it.
      • The plastic button assembly has a ribbon cable connected on the bottom, so be careful pulling it.
      Pergunte ao FixBot
      Comentar
    9. Canon Pixma MP480 Buttons Replacement: passo 20, imagem 1 %32
      • Remove the ribbon cable connected to the backside of the plastic button assembly.
      Pergunte ao FixBot
      Comentar
    10. Canon Pixma MP480 Buttons Replacement: passo 21, imagem 1 %32 Canon Pixma MP480 Buttons Replacement: passo 21, imagem 2 %32
      • Remove the seven 8.7 mm screws using the Phillips #1 screwdriver.
      Pergunte ao FixBot
      Comentar
    11. Canon Pixma MP480 Buttons Replacement: passo 22, imagem 1 %32 Canon Pixma MP480 Buttons Replacement: passo 22, imagem 2 %32 Canon Pixma MP480 Buttons Replacement: passo 22, imagem 3 %32
      • Locate the spring that holds the PCB in place on the bottom left of the plastic button assembly.
      • Gently lift the spring and pull the board out of its plastic button assembly.
      Pergunte ao FixBot
      Comentar
    12. Canon Pixma MP480 Buttons Replacement: passo 23, imagem 1 %32
      • Remove the buttons from the plastic button assembly.
      Pergunte ao FixBot
      Comentar
Conclusão
Equipe
Cal Poly, Team 19-41, Regan Winter 2013 Membro de Cal Poly, Team 19-41, Regan Winter 2013
CPSU-REGAN-W13S19G41
4 Membros
Autoria de 42 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 7
Últimos 30 dias: 37
Ao todo: 2,210
