Ir para o conteúdo principal
Canon PIXMA iP3600 Printhead Replacement
    1. Canon PIXMA iP3600 Printhead Replacement, Ink Cartridges: passo 1, imagem 1 %32
      • Press the power button to turn on the printer.
      Pergunte ao FixBot
      Comentar
    2. Canon PIXMA iP3600 Printhead Replacement: passo 2, imagem 1 %32
      • Pull down the front output tray cover.
      Pergunte ao FixBot
      Comentar
    3. Canon PIXMA iP3600 Printhead Replacement: passo 3, imagem 1 %32
      • Lift the printer lid.
      Pergunte ao FixBot
      Comentar
    4. Canon PIXMA iP3600 Printhead Replacement: passo 4, imagem 1 %32
      • Allow the belt, containing ink cartridges, to adjust and center so that the ink cartridges are visible.
      Pergunte ao FixBot
      Comentar
    5. Canon PIXMA iP3600 Printhead Replacement: passo 5, imagem 1 %32 Canon PIXMA iP3600 Printhead Replacement: passo 5, imagem 2 %32
      • Push in the white clip to release the ink cartridge from the printhead.
      • Lift the ink cartridge from the printhead.
      • Repeat this process for the remaining ink cartridges.
      • You have successfully removed all ink cartridges.
      Pergunte ao FixBot
      Comentar
    1. Canon PIXMA iP3600 Printhead Replacement, Printhead: passo 6, imagem 1 %32
      • After removing all ink cartridges, lift the printhead lock lever.
      Pergunte ao FixBot
      Comentar
    2. Canon PIXMA iP3600 Printhead Replacement: passo 7, imagem 1 %32
      • Pull up and lift out the black piece that previously held the ink cartridges. This is the printhead.
      Pergunte ao FixBot
      Comentar
    3. Canon PIXMA iP3600 Printhead Replacement: passo 8, imagem 1 %32
      • You have successfully removed your printhead.
      Pergunte ao FixBot
      Comentar
Conclusão
6 outras pessoas executaram este guia.
Caitlyn
Membro desde: 10/07/14
1.223 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team 1-3, Leahy Fall 2014 Membro de USF Tampa, Team 1-3, Leahy Fall 2014
USFT-LEAHY-F14S1G3
3 Membros
Autoria de 8 guias
1Comentário do guia
fairly helpful, especially the photo's. but I need advice on how to clean the printhead before trying to replace it,
a1halber - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 17
Últimos 30 dias: 78
Ao todo: 9,544
