Ir para o conteúdo principal
Canon PIXMA iP3600 Ink Cartridges Replacement
    1. Canon PIXMA iP3600 Ink Cartridges  Replacement, Ink Cartridges: passo 1, imagem 1 %32
      • Press the power button to turn on the printer.
      Pergunte ao FixBot
      Comentar
    2. Canon PIXMA iP3600 Ink Cartridges  Replacement: passo 2, imagem 1 %32
      • Pull down the front output tray cover.
      Pergunte ao FixBot
      Comentar
    3. Canon PIXMA iP3600 Ink Cartridges  Replacement: passo 3, imagem 1 %32
      • Lift the printer lid.
      Pergunte ao FixBot
      Comentar
    4. Canon PIXMA iP3600 Ink Cartridges  Replacement: passo 4, imagem 1 %32
      • Allow the belt, containing ink cartridges, to adjust and center so that the ink cartridges are visible.
      Pergunte ao FixBot
      Comentar
    5. Canon PIXMA iP3600 Ink Cartridges  Replacement: passo 5, imagem 1 %32 Canon PIXMA iP3600 Ink Cartridges  Replacement: passo 5, imagem 2 %32
      • Push in the white clip to release the ink cartridge from the printhead.
      • Lift the ink cartridge from the printhead.
      • Repeat this process for the remaining ink cartridges.
      • You have successfully removed all ink cartridges.
      Pergunte ao FixBot
      Comentar
Conclusão
4 outras pessoas executaram este guia.
Caitlyn
Membro desde: 10/07/14
1.223 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team 1-3, Leahy Fall 2014 Membro de USF Tampa, Team 1-3, Leahy Fall 2014
USFT-LEAHY-F14S1G3
3 Membros
Autoria de 8 guias
1Comentário do guia
Hi, all the years I've been using original ink but it became so expensive and my cuz gave me generic ones. I've installed it last night but then noticed that my images totally not the same on my writeable dvd's,eg. brown colour images (faces) or yellowish.
Is it because of the generic ink cartridges or is there a problem with the printer.
Please help me urgently?
You can even email me directly msmidt@distell.co.za
Marlin - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 7
Últimos 30 dias: 49
Ao todo: 5,415
