Ir para o conteúdo principal
Canon PIXMA iP3600 AC Adapter Replacement
    1. Canon PIXMA iP3600 AC Adapter Replacement, AC Adapter: passo 1, imagem 1 %32 Canon PIXMA iP3600 AC Adapter Replacement, AC Adapter: passo 1, imagem 2 %32
      • It is very important to disconnect your printer from the outlet before attempting replacement. This ensures that there is no power reaching the AC adapter.
      • Remove power cord by disconnecting it from the AC Adapter.
      Pergunte ao FixBot
      Comentar
    2. Canon PIXMA iP3600 AC Adapter Replacement: passo 2, imagem 1 %32 Canon PIXMA iP3600 AC Adapter Replacement: passo 2, imagem 2 %32
      • Pinch upper and lower prongs, moving them away from the AC adapter.
      Pergunte ao FixBot
      Comentar
    3. Canon PIXMA iP3600 AC Adapter Replacement: passo 3, imagem 1 %32 Canon PIXMA iP3600 AC Adapter Replacement: passo 3, imagem 2 %32
      • The AC adapter will now be loose, and able to come away from the printer.
      • Grasp the AC adapter and pull it toward you to remove it.
      Pergunte ao FixBot
      Comentar
    4. Canon PIXMA iP3600 AC Adapter Replacement: passo 4, imagem 1 %32
      • Rotate the AC adapter toward you so that the blue cord, with white connector head, is facing you.
      Pergunte ao FixBot
      Comentar
    5. Canon PIXMA iP3600 AC Adapter Replacement: passo 5, imagem 1 %32 Canon PIXMA iP3600 AC Adapter Replacement: passo 5, imagem 2 %32 Canon PIXMA iP3600 AC Adapter Replacement: passo 5, imagem 3 %32
      • Grasp the white connector head that is attached to the end of the blue cord.
      • Disconnect the white connector head by gently pulling it away from the AC adapter.
      • You have successfully removed the AC adapter.
      Pergunte ao FixBot
      Comentar
Conclusão
7 outras pessoas executaram este guia.
Caitlyn
Membro desde: 10/07/14
1.223 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team 1-3, Leahy Fall 2014 Membro de USF Tampa, Team 1-3, Leahy Fall 2014
USFT-LEAHY-F14S1G3
3 Membros
Autoria de 12 guias
3Comentários do guia
Does anybody know the pin-out for these power supplies?
James Rudee - Responder Compartilhar
WHERE CAN I BUY AC ADAPTER PIXMA GM 5220 PRINTER ? PLAESE !! my cell 678 899 1187, 770368 0409 w
vincent lieu - Responder Compartilhar
Well I’ve just taken the AC Adapter out - I’ll let you know if a the replacement works once I’ve purchased it - Which I am hesitant to buy in case that’s not the problem.
The printer is barely 2 years old and barely used, I shouldn’t be experiencing this problem of the printer not turning on.
Canon you need to get your act together if you would like to stay in business, I’m seeing a lot of comments on this problem over a range of different printer models - Mine is a Pixma iX6860.
rezidraft - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 19
Últimos 30 dias: 62
Ao todo: 5,969
