Introdução
This replacement is not easy and takes a considerable amount of time. This guide will show you how to safely remove the ink head from your printer.
O que você precisa
There are a few tabs on the top of the panel that hook down and into the black side panel. Insert the tool in-between the black panel and the blue panel as shown and pull the two pieces apart.
Unscrew the three screws holding the rail.
Remove the cord by pulling upwards on it and unhooking it from the pulleys on either end.
4 outras pessoas executaram este guia.
