Ir para o conteúdo principal
Canon PIXMA MP620B Command Screen Replacement
O que você precisa
    1. Canon PIXMA MP620B Command Screen Replacement, Open Printer Lid: passo 1, imagem 1 %32
      • Open top lid of the printer to reveal the scanner
      Pergunte ao FixBot
      Comentar
    2. Canon PIXMA MP620B Command Screen Replacement, Pull apart the two large lid plates: passo 2, imagem 1 %32 Canon PIXMA MP620B Command Screen Replacement, Pull apart the two large lid plates: passo 2, imagem 2 %32
      • Insert the spudger tool into the top lid in between the blue and the black panels.
      • Use this tool to pry the two panels apart
      Pergunte ao FixBot
      Comentar
    3. Canon PIXMA MP620B Command Screen Replacement, Take apart the two sections: passo 3, imagem 1 %32
      • After these two panels are separated, set the top panel to the side for now
      Pergunte ao FixBot
      Comentar
    4. Canon PIXMA MP620B Command Screen Replacement, Pull out wires leading to screen assembly: passo 4, imagem 1 %32
      • Unplug the two wires shown at the right of the command screen
      Pergunte ao FixBot
      Comentar
    5. Canon PIXMA MP620B Command Screen Replacement, Unscrew screen assembly: passo 5, imagem 1 %32
      • Unscrew the four screws shown to detach the command screen from the printer
      Pergunte ao FixBot
      Comentar
    6. Canon PIXMA MP620B Command Screen Replacement, Replace assembly: passo 6, imagem 1 %32
      • Take the detached command screen off of the printer and replace.
      Pergunte ao FixBot
      Comentar
Conclusão
4 outras pessoas executaram este guia.
Equipe
Cal Poly, Team 6-21, Maness Fall 2014 Membro de Cal Poly, Team 6-21, Maness Fall 2014
CPSU-MANESS-F14S6G21
4 Membros
Autoria de 35 guias
2Comentários do guia
Ideas as to where to buy replacement screen assembly?
davepi49 - Responder Compartilhar
same question
Jan de Ruiter - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 34
Ao todo: 1,931
