Ir para o conteúdo principal
Canon ImageCLASS MF4350d Transformer Replacement
O que você precisa
    1. Canon ImageCLASS MF4350d Transformer Replacement, Front Paneling: passo 1, imagem 1 %32
      • Lift the printer lid up as shown in the photo.
      Pergunte ao FixBot
      Comentar
    2. Canon ImageCLASS MF4350d Transformer Replacement: passo 2, imagem 1 %32 Canon ImageCLASS MF4350d Transformer Replacement: passo 2, imagem 2 %32
      • Locate and remove the two 10mm side screws. There is one on each side.
      Pergunte ao FixBot
      Comentar
    3. Canon ImageCLASS MF4350d Transformer Replacement: passo 3, imagem 1 %32 Canon ImageCLASS MF4350d Transformer Replacement: passo 3, imagem 2 %32
      • Unhook the plastic panel from the printer starting from the top.
      • You may need to wiggle the panel a bit to loosen it.
      • To remove the bottom part of the paneling gently lay the printer on its back.
      • The scanner lid needs to be supported when moving the printer
      Pergunte ao FixBot
      Comentar
    1. Canon ImageCLASS MF4350d Transformer Replacement, Right Side Paneling: passo 4, imagem 1 %32 Canon ImageCLASS MF4350d Transformer Replacement, Right Side Paneling: passo 4, imagem 2 %32 Canon ImageCLASS MF4350d Transformer Replacement, Right Side Paneling: passo 4, imagem 3 %32
      • Gently unhook the right side paneling (as looking at the printer's front face) from the printer.
      • Use a gentle back and forth motion to wiggle the hooks out.
      Pergunte ao FixBot
      Comentar
    1. Canon ImageCLASS MF4350d Transformer Replacement, Transformer: passo 5, imagem 1 %32 Canon ImageCLASS MF4350d Transformer Replacement, Transformer: passo 5, imagem 2 %32
      • Locate the yellow wire connected to the metal box.
      • Carefully pull the yellow wire from the black connector.
      • Wires may detach completely from plug so tug very gently.
      Pergunte ao FixBot
      Comentar
    2. Canon ImageCLASS MF4350d Transformer Replacement: passo 6, imagem 1 %32 Canon ImageCLASS MF4350d Transformer Replacement: passo 6, imagem 2 %32
      • Locate the spring.
      • Unhook the spring on the side of the metal box.
      Pergunte ao FixBot
      Comentar
    3. Canon ImageCLASS MF4350d Transformer Replacement: passo 7, imagem 1 %32
      • Unscrew the 10mm screw attaching the metal plate to the printer.
      Pergunte ao FixBot
      Comentar
    4. Canon ImageCLASS MF4350d Transformer Replacement: passo 8, imagem 1 %32
      • Lift the transformer out of the printer.
      Pergunte ao FixBot
      Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Helena Yanez
Membro desde: 09/29/13
470 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 13-1, Forte Fall 2013 Membro de Cal Poly, Team 13-1, Forte Fall 2013
CPSU-FORTE-F13S13G1
5 Membros
Autoria de 57 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 37
Ao todo: 3,523
