Ir para o conteúdo principal
Canon FS30 Memory Card Replacement
    1. Canon FS30 Memory  Card Replacement, Memory  Card: passo 1, imagem 1 %32 Canon FS30 Memory  Card Replacement, Memory  Card: passo 1, imagem 2 %32
      • Locate battery compartment cover. Turn the device over and locate the battery compartment cover.
      • Open Battery Compartment Cover. Place a finger or thumb on the textured section of the battery compartment cover and push forward until you hear a click. Then lift the battery compartment cover.
      Pergunte ao FixBot
      Comentar
    2. Canon FS30 Memory  Card Replacement: passo 2, imagem 1 %32 Canon FS30 Memory  Card Replacement: passo 2, imagem 2 %32
      • Locate the memory card and press it until you hear a click.
      • On removing your finger, the memory card should pop out.
      • Remove the memory card.
      Pergunte ao FixBot
      Comentar
Conclusão
Emanuel Keller
Membro desde: 02/28/17
419 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team S1-G4, Nance Spring 2017 Membro de USF Tampa, Team S1-G4, Nance Spring 2017
USFT-NANCE-S17S1G4
4 Membros
Autoria de 10 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 13
Ao todo: 339
