Introdução
After long term use, it is possible that the shutter button on your camera needs to be replaced. While replacing this component may be somewhat involved, it can restore functionality to your camera.
O que você precisa
Place the camera upside down, and position it to where the back of the camera is visible.
Place the camera on its side with the soft touch grip facing up and the top of the camera facing right.
Remove the three black M3x4mm JIS #000 screws on the bottom of the camera.
Remove the following screws from the bottom of the camera:
Two M3x4.5mm JIS #000 screws
One M3x3mm JIS #000 screw
Remove the following screws from around the viewfinder:
One 10mm JIS #00 diopter screw
Two M3x6mm JIS #00 screws
Use a JIS #00 screwdriver to remove the two silver 4 mm screws from underneath the shutter button.
