Ir para o conteúdo principal
Canon EOS Rebel XTi Memory Card Replacement
O que você precisa
    1. Canon EOS Rebel XTi Memory Card Replacement, Memory Card: passo 1, imagem 1 %32
      • Place the camera on its side with the soft touch grip facing up and the top of the camera facing right.
      Pergunte ao FixBot
      Comentar
    2. Canon EOS Rebel XTi Memory Card Replacement: passo 2, imagem 1 %32
      • Slide the memory card door in the direction of the arrow engraved on the camera.
      • Once the door has slid open to its full position, lift up on the door.
      Pergunte ao FixBot
      Comentar
    3. Canon EOS Rebel XTi Memory Card Replacement: passo 3, imagem 1 %32
      • With the door open, push down the small black plunger next to the CF slot. The CF card will disengage from the slot and be ejected far enough that you can grasp it between thumb and forefinger and remove it from the slot.
      • The plunger will stay in its depressed position until a CF card is again inserted in the slot.
      Pergunte ao FixBot
      Comentar
Conclusão
Equipe
USF Tampa, Team 8-6, Eyestone Fall 2015 Membro de USF Tampa, Team 8-6, Eyestone Fall 2015
USFT-EYESTONE-F15S8G6
3 Membros
Autoria de 19 guias
1Comentário do guia
My camara wont read memory card
mcbed215 - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 13
Últimos 30 dias: 56
Ao todo: 4,304
