Ir para o conteúdo principal
Canon EOS Rebel T4i Flash Bulb Replacement
O que você precisa
  1. Canon EOS Rebel T4i Flash Bulb Replacement, Battery: passo 1, imagem 1 %32
    • Locate the battery cover at the bottom of the camera.
    • Pull down on the black tab to open the cover.
  2. Canon EOS Rebel T4i Flash Bulb Replacement: passo 2, imagem 1 %32
    • Push the grey tab on the right side of the battery.
    • Remove the battery from the slot.
  3. Canon EOS Rebel T4i Flash Bulb Replacement, Flash Bulb: passo 3, imagem 1 %32
    • Electric Shock Warning: There is a high voltage capacitor on the DC PCB board which powers the flash. It is recommended that you use a capacitor discharge tool to ensure the capacitor is fully discharged before proceeding with this guide.
    • Using a JIS #000 screwdriver, unscrew the two 4.9mm JIS screws which are located underneath the flash.
  4. Canon EOS Rebel T4i Flash Bulb Replacement: passo 4, imagem 1 %32
    • Remove the covering.
  5. Canon EOS Rebel T4i Flash Bulb Replacement: passo 5, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Use the tweezers to remove the excess glue around the wiring. This will allow you to cut the wire and remove the light in the next step.
  6. Canon EOS Rebel T4i Flash Bulb Replacement: passo 6, imagem 1 %32
    • Use the wire cutters to cut the wiring connected to the flash.
Conclusão
10 outras pessoas executaram este guia.
Jordan Rabold
Membro desde: 04/14/14
807 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 12-33, Maness Spring 2014 Membro de Cal Poly, Team 12-33, Maness Spring 2014
CPSU-MANESS-S14S12G33
4 Membros
Autoria de 14 guias
3 comentários
how do you reverse step 6 - cutting the wires?
jeremyyoung - Responder
You dont tell how to make sure capacitors are discharged before changing the flash ? and do you know what is the replacement number of the flash bulb itself ?
jackqc09 - Responder
No parts required? So I can repair my flash not having to buy a new bulb? haha Please, I need the link from where I repair my burned built-in flash :/
gustavoaleme - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 16
Últimos 30 dias: 41
Ao todo: 4,666
