Ir para o conteúdo principal
Canon EOS Rebel T3 Image Sensor Replacement
O que você precisa
  1. Canon EOS Rebel T3 Image Sensor Replacement, I/F Terminal Cover: passo 1, imagem 1 %32 Canon EOS Rebel T3 Image Sensor Replacement, I/F Terminal Cover: passo 1, imagem 2 %32 Canon EOS Rebel T3 Image Sensor Replacement, I/F Terminal Cover: passo 1, imagem 3 %32
    • Pry open the rubber I/F terminal cap with your finger.
    • Remove the two M1.7x4.5mm JIS #000 screws that are underneath the I/F terminal cap.
    • Using a plastic pick, or another thin plastic prying tool, pop off the I/F terminal cover from the camera.
  2. Canon EOS Rebel T3 Image Sensor Replacement, Back Cover: passo 2, imagem 1 %32 Canon EOS Rebel T3 Image Sensor Replacement, Back Cover: passo 2, imagem 2 %32
    • On the left side of the camera, remove the following screw:
    • One M1.7x4.5mm JIS #000 screw
    • On the right side, remove the following screws:
    • One M1.7x5.5mm JIS #000 screw
  3. Canon EOS Rebel T3 Image Sensor Replacement: passo 3, imagem 1 %32 Canon EOS Rebel T3 Image Sensor Replacement: passo 3, imagem 2 %32
    • Remove the battery door.
    • Open the battery door to about a 35° angle.
    • Pull the battery door straight outwards.
    • Remove the following screws from the bottom of the camera:
    • Two M1.7x4.5mm JIS #000 screws
    • Two M1.7x3.0mm JIS #000 screws
  4. Canon EOS Rebel T3 Image Sensor Replacement: passo 4, imagem 1 %32 Canon EOS Rebel T3 Image Sensor Replacement: passo 4, imagem 2 %32 Canon EOS Rebel T3 Image Sensor Replacement: passo 4, imagem 3 %32
    • Carefully lift the back cover partially off of the camera.
    • There are two ribbon cables still connecting the back cover to the camera.
    • Disconnect the right most ribbon cables from the main PCB board.
    • Use a plastic spudger to lift up the black locking tab.
    • Pull out the ribbon cable from its connector using a pair of angled tweezers.
    • With this ribbon cable disconnected, you will be able to move the back cover slightly farther away from the camera, giving you more room to remove the remaining ribbon cable.
    • Remove the left ribbon cable using the same two steps as with the other ribbon cable.
  5. Canon EOS Rebel T3 Image Sensor Replacement, Front Cover: passo 5, imagem 1 %32
    • Remove the following screws on the front of the camera.
    • Two M1.7x5.5mm JIS #000 screws
  6. Canon EOS Rebel T3 Image Sensor Replacement: passo 6, imagem 1 %32
    • On the bottom of the camera, remove the following screws:
  7. Canon EOS Rebel T3 Image Sensor Replacement: passo 7, imagem 1 %32 Canon EOS Rebel T3 Image Sensor Replacement: passo 7, imagem 2 %32 Canon EOS Rebel T3 Image Sensor Replacement: passo 7, imagem 3 %32
    • Slide a spudger tool towards the tripod mount, underneath the plastic cover.
    • Push the plastic cover up and over the tripod mount.
    • Pull the front cover off of the camera.
    • Electric Shock Warning: With the front cover off, the high voltage capacitor on the DC PCB board is now exposed. It is recommended that you use a capacitor discharge tool to ensure the capacitor is fully discharged before proceeding further.
  8. Canon EOS Rebel T3 Image Sensor Replacement, Top Cover: passo 8, imagem 1 %32 Canon EOS Rebel T3 Image Sensor Replacement, Top Cover: passo 8, imagem 2 %32
    • Push up and slide off the eyepiece.
    • Remove the following screws:
    • Two M1.7x2.5mm JIS #000 screws
    • One M1.7x3.6mm JIS #000 diopter screw
  9. Canon EOS Rebel T3 Image Sensor Replacement: passo 9, imagem 1 %32
    • Remove the following screws on the top of the camera:
    • One M1.7x2.5mm JIS #000 screw
  10. Canon EOS Rebel T3 Image Sensor Replacement: passo 10, imagem 1 %32 Canon EOS Rebel T3 Image Sensor Replacement: passo 10, imagem 2 %32
    • Disconnect the microphone cable from the main PCB board.
    • Position a flathead 2.5mm screwdriver between the main PCB board connector and the microphone connector.
    • Gently wiggle the flathead screwdriver back and forth until the microphone connector comes free.
    • If you do not have a flathead 2.5mm screwdriver, another similarly sized flathead screwdriver should work.
  11. Canon EOS Rebel T3 Image Sensor Replacement: passo 11, imagem 1 %32 Canon EOS Rebel T3 Image Sensor Replacement: passo 11, imagem 2 %32 Canon EOS Rebel T3 Image Sensor Replacement: passo 11, imagem 3 %32
    • Locate the mode dial ribbon cable on the main PCB board.
    • Use a plastic spudger tool to carefully lift up the locking tab.
    • Use caution when handling ribbon connectors and their connectors.
    • Use a pair of angled tweezers to pull the ribbon cable out of the connector.
  12. Canon EOS Rebel T3 Image Sensor Replacement: passo 12, imagem 1 %32 Canon EOS Rebel T3 Image Sensor Replacement: passo 12, imagem 2 %32
    • Gently lift up the top cover.
    • There are still several cables connecting the top cover to the camera. Be careful to not pull on these cables while lifting up the top cover.
    • Set the top cover down, making sure not to pull on the cables still attached.
  13. Canon EOS Rebel T3 Image Sensor Replacement, Main PCB Board: passo 13, imagem 1 %32 Canon EOS Rebel T3 Image Sensor Replacement, Main PCB Board: passo 13, imagem 2 %32 Canon EOS Rebel T3 Image Sensor Replacement, Main PCB Board: passo 13, imagem 3 %32
    • Use caution while handling ribbon cables and ribbon cables connects to avoid damaging them.
    • Locate the two ribbon cables on the main PCB board which are marked in the picture.
    • Disconnect the ribbon cables.
    • These ribbon cables features a hole in them which can assist with disconnecting them. Use either a pair of tweezers or another tool with a thin point to pull out the ribbon cables utilizing this hole.
    • Use a plastic spudger tool to carefully push up and disconnect the imaging sensor ribbon cable.
  14. Canon EOS Rebel T3 Image Sensor Replacement: passo 14, imagem 1 %32
    • Locate the remaining four ribbon cables connected to the main PCB board.
    • Gently push up on the plastic lock tabs to unlock each of the ribbon cable connectors. Be especially careful with the wide lock tab, as it is particularly fragile.
    • Disconnect each ribbon cable from the main PCB board.
    • Use the same method from the previous step to remove these cables.
  15. Canon EOS Rebel T3 Image Sensor Replacement: passo 15, imagem 1 %32 Canon EOS Rebel T3 Image Sensor Replacement: passo 15, imagem 2 %32
    • Remove the following screws on the main PCB board:
    • Three M1.7x2.5mm Phillips #000 screws
    • Two M1.7x4.5mm Phillips #000 screws
    • Slide off the metal I/F terminal shield.
  16. Canon EOS Rebel T3 Image Sensor Replacement: passo 16, imagem 1 %32 Canon EOS Rebel T3 Image Sensor Replacement: passo 16, imagem 2 %32
    • Tilt the main PCB board upwards to reveal the remaining cable connection.
    • Grab the two cables going into the connector, grabbing them as close to the connector as you can.
    • Carefully pull the connector straight out.
  17. Canon EOS Rebel T3 Image Sensor Replacement, Image Sensor: passo 17, imagem 1 %32 Canon EOS Rebel T3 Image Sensor Replacement, Image Sensor: passo 17, imagem 2 %32
    • Using a plastic spudger tool, carefully push up and disconnect the ribbon cable from the image sensor.
    • Remove the following screws from the image sensor:
    • Two M1.7x1.6mm JIS #000 screws
    • Three M1.7x5.5mm Phillips #000 screws
  18. Canon EOS Rebel T3 Image Sensor Replacement: passo 18, imagem 1 %32
    • Gently lift the image sensor straight up and away from the camera.
    • Use extreme care while handling the image sensor, especially if you place on reinstalling the same image sensor back into the camera. The use of an anti-static wrist band is highly recommended. Avoid touching the front of the sensor with your fingers or any tools.
    • When placing the image sensor down, place it with the sensor facing upwards. You may also want to place a container over the image sensor to prevent any dust from settling on it.
    • If there is any dust or smudges on the sensor, you may consider performing a wet clean on the sensor while it is removed from the camera if you are planning on reinstalling it. Be sure to use a proper sensor cleaning kit and to follow their cleaning instructions.
Conclusão
Documentos anexados
Zephosk
Membro desde: 09/26/24
5.457 Reputação
Autoria de 34 guias
Equipe
LGBTQ Technicians Membro de LGBTQ Technicians
Community
48 Membros
Autoria de 77 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 26
Ao todo: 301
